Maybe our motorhomes are getting a little heavy... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: Towing (/forumdisplay.php?fid=32) +--- Thread: Maybe our motorhomes are getting a little heavy... (/showthread.php?tid=11271) |
Maybe our motorhomes are getting a little heavy... - davidbrady - 05-09-2018 17:53 Published on May 3, 2018, KRTV, Montana's News Leader: RE: Maybe our motorhomes are getting a little heavy... - ernie ekberg - 05-09-2018 19:39 I just came back from a trip there in montana. The state has had way too much moisture and parking lots are mushy RE: Maybe our motorhomes are getting a little heavy... - Arcticdude - 05-09-2018 22:21 Those new P50's are grossing at 63,000 if I recall correctly. Sad that a new one has to go through that. And I really hope that wasn't the MacKillop's changing brands! That is to say that I would understand if they did, but would really hate for this to be their maiden voyage in the new rig! RE: Maybe our motorhomes are getting a little heavy... - ernie ekberg - 05-10-2018 09:15 is Ross buying a Newell? RE: Maybe our motorhomes are getting a little heavy... - dentmac - 05-10-2018 12:43 NO ! 63,000 GVWR ! where is that legal ? 44,600 on the rear Note that it is now legal to have 24,000 on one axle If I could....PREVOST ! Burned once.... not again! RE: Maybe our motorhomes are getting a little heavy... - davidbrady - 05-10-2018 18:32 (05-10-2018 12:43)dentmac Wrote: If I could....PREVOST ! Attaboy Ross! Here's the GAWR specs for the P50: Gross vehicle-weight rating 63,300 lbs. Gross axle-weight rating, front 20,000 lbs. Gross axle-weight rating, drive 28,600 lbs. Gross axle-weight rating, tag 16,000 lbs. RE: Maybe our motorhomes are getting a little heavy... - mbulriss - 05-10-2018 22:40 Don’t those axle weight ratings add up to 64,400? In any event, those owners aren’t going to be on the Ohio Turnpike with that drive axle fully loaded. LOL Coincidentally, I looked at a Newell built stacker on Wednesday. It was also rediculously heavy. RE: Maybe our motorhomes are getting a little heavy... - dentmac - 05-11-2018 00:05 The discrepancy can be due to the Drive:Tag ratio. Usually 60:40 (or 65:35 if you are trying to lighten the front end ) ( a BB trick ) As RV load increases, and one axle approaches max. GAWR the other axle is not at its maximum due to the ratio. The outcome is less load than the simple addition of the 2 axles GAWR.May not be true , but sounds good Eh! |
