Roadside assistance plans - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: Towing (/forumdisplay.php?fid=32) +--- Thread: Roadside assistance plans (/showthread.php?tid=11273) |
Roadside assistance plans - davidbrady - 05-16-2018 11:12 Who has the best roadside assistance plans? Coach-Net, Good Sams (Allstate), FMCA, etc. Who would you recommend? RE: Roadside assistance plans - dentmac - 05-16-2018 22:25 Good Sam experience was not good. Left us at a Flying J pump overnight. Every time you call, you have to go through the initial identification routine; numbers , name , address. Reimbursement was $100 short. Now with Coach Net. Hopefully I will not have a comparison to post. Ross RE: Roadside assistance plans - patticake - 05-17-2018 09:52 First time(last century) I used Good Sam, it was great. Next time(this century), I was left on side of road for over 6 hours while they decide where to take me and then dispatch a slide back. Used coach net several times and they were great. Called back several times to make sure we were safe and had a wrecker dispatched quickly. One time, when I had a blow out, tire guy was there within half hour. RE: Roadside assistance plans - davidbrady - 05-17-2018 23:32 Thanks, I appreciate the info. Coach-Net it is then. RE: Roadside assistance plans - ernie ekberg - 05-18-2018 07:57 I have had Coach-Net for years and never an issue RE: Roadside assistance plans - mbulriss - 05-18-2018 22:56 Another perspective. I’ve had Coach-Net coverage for 12-15 years. I consider them insurance of last resort. I’ve had to use them three times. I’ve never had a response in under 8 hours, once nearly 24 hours later - in a major city for a broken leveling valve. Two added all sort of extra charges when they showed up even with Coach-Net on the line. I got reimbursed for only one of those instances. Relatively inexpensive insurance of last resort if a tow was required. And they seem to be better than the other choices, but far from outstanding in my experience. Kind of like my umbrella insurance - I hope never to use it, but I sure keep it in force. RE: Roadside assistance plans - patticake - 05-19-2018 12:03 If and when you have to use them, be sure to tell them that you are a BUS, and add your weight, length, and height. Then, make them repeat it back to you. If possible, ask for a slideback, not a wrecker. That way the driver doesn't have to disconnect the driveshaft, or remove the axles. I have had a one ton wrecker come out to me, and the driver said that he was told that it was a small motorhome. Remember, you are dealing with someone that does not know anything about motorhomes. |
