fuel solenoid-intermitent and low voltage - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: fuel solenoid-intermitent and low voltage (/showthread.php?tid=1128) |
fuel solenoid-intermitent and low voltage - bus2nut - 07-31-2005 11:34 While driving my motor srtopped.I checked fuel prime and it was ok. I found out that there was no voltage to the fuel solenoid.I ran a temperary wire from a relay up front and it has worked since.I have a 3208t installed in a 1982fc in 1995.There appears to be a one volt drop to the fuel solenoid.The oil presure is 75 psi.Is the low oil pressure switch tied in to the solenoid and if so where can i locate it?What and where is the relay that supplys power to the solenoid? Ken Kalmakoff 1982fc 3208t Richmond BC Canada |
