Max Fuel Flow Light - Printable Version
+--- Thread: Max Fuel Flow Light (/showthread.php?tid=1129)
Max Fuel Flow Light - Steve Johnson - 07-31-2005 14:34
We just returned from a week long trip. The first day out, at some
point, the Max Fuel Flow light stuck on. The next two days the light
came on as soon as the ignition key was turned on (even prior to
starting the engine) and stayed on until we turned the engine off.
The next day it worked properly at first, but after about 20 minutes
stuck on again. The last two days, the light worked properly. It
sounds like a sensor may be going bad? Any advice would be
appreciated.
Thank you,
Steve Johnson
Grand Rapids, MI
'82 FC35
Max Fuel Flow Light - Chris - 08-04-2006 01:36
Should my Max Fuel Flow light be on all the time?
It has been on most of the time but I have noticed it go on and off
some now.
Thanks
Chris Reed
83 FC35 SB
Plant City, FL
Max Fuel Flow Light - Jeff Miller - 08-04-2006 01:51
The Max Fuel Flow light is turned on by the fuel pump / governor.
Whenever the power/fuel-flow your pedal is calling for is limited by
the governor, it grounds the wire and turns on the light.
The wire is connected to the top of the fuel injection pump. If it
becomes shorted to ground anywhere (likely on the engine), it will turn
on the light. Check the wire. Check other wires on the engine while
you're in there.
- Jeff Miller
in Holland, MI
--- In WanderlodgeForum@yahoogroups.com, "Chris"
> some now.
> Thanks
> Chris Reed
> 83 FC35 SB
> Plant City, FL
Max Fuel Flow Light - davidkerryedwards - 08-04-2006 01:54
No, it shouldn't be on all the time. It should only come on under
full load or close. The PO of my coach said the light stayed on when
the air cleaner was dirty.
Kerry
82 FC 35
Denver
> some now.
> Thanks
> Chris Reed
> 83 FC35 SB
> Plant City, FL
Max Fuel Flow Light - D - 07-17-2007 04:25
Had to dig this one up and thank the member who helped me out of a
problem. Searching through the posts I found this on my journey as
to why my "max fuel flow light" stays on. Changed the filter and now
it went away. Thanks, David for your post.
Dru and Debora
'83FC 35 RB
when
> Kerry
> 82 FC 35
> Denver
off
> > some now.
> > Thanks
> > Chris Reed
> > 83 FC35 SB
> > Plant City, FL
