| Air Suspension Question - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Suspension Question (/showthread.php?tid=1130) |
| Air Suspension Question - Steve Johnson - 07-31-2005 14:39 When airing up our suspension (switching the Susp Dump switch) I noticed that sometimes the bus did not air up evenly. The first time I noticed the problem, the passenger side came up and the driver's side did not. Another time it was the opposite. Both times, I dumped the suspensiona and tried it again, and it seemed to come up OK. But, several times I noticed that one side came up faster than the other. There were even a few times running down the road that I thought I felt the bus lean one way or the other. Any suggestions on what I should check? Thank you, Steve Johnson Grand Rapids, MI '82 FC35 Air Suspension Question - erniecarpet@... - 07-31-2005 21:36 Steve- there is a ride height valve that gets stuck, sometimes. I know on my coach, that upon start-up- the left side does not air up. I have a left turn out of the drive and when the coach leans to the right, she airs up- called an Ernie fix. Ernie -83pt40 in Montana [Non-text portions of this message have been removed] |
