Roadstar 2000 Omnidirectional - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Roadstar 2000 Omnidirectional (/showthread.php?tid=1162) |
Roadstar 2000 Omnidirectional - Curt Sprenger - 08-08-2005 10:08 Our original stand up TV antenna does not work. Is the Roadstar 2000 Omnidirectional a good replacement antenna? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Roadstar 2000 Omnidirectional - sfedeli3 - 08-08-2005 13:52 Hi Curt, That's what I put on my coach. Had to run new wiring from the antenna to where the old cables went due to built-in amp in the Road Star. Was not hard, provided you're able to remove some roof trim and overhead stuff. Be glad to send photos of installation if you need them. Took about 5 hours. I get good images from about 25 miles away in flat country. Was down at Newport Dunes and was able to get around 8 channels. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > Our original stand up TV antenna does not work. Is the Roadstar 2000 > Omnidirectional a good replacement antenna? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. |
