'83 FC Won't Start... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: '83 FC Won't Start... (/showthread.php?tid=1173) |
'83 FC Won't Start... - erniecarpet@... - 08-09-2005 10:45 Ken, you might take off the grounds- on the starter and everywhere else you can find. Grounding- or lack of, is the largest culprit to our coaches. There is one on your starter and there is another one close to your batteries. A good flashlite- if your over 50 , like me, is a must to find these. Ernie-83pt40 in cool montana [Non-text portions of this message have been removed] '83 FC Won't Start... - imgetnab2 - 08-09-2005 14:42 I'm still trying to find the culprit to my bus not starting. When I turn it over, the engine briefly turns slowly, and then I get the "da-da-da-da-da-da" of what sounds like dead batteries. I had the batteries load tested, and they all failed, so I purchased 4 new ones, and also replaced the battery cables in the battery compartment. After replacement, I still get the same "weak battery" response from the engine. I am measuring 12.55 volts at the starter, and even when charging the batteries with the generator, I can't get any different reaction from the engine... Am I missing something obvious that I need to check? I've also checked the cable connections back by the door, and they seem to be good. Are there other cable junctions that I may have missed, or particular areas I should check? Any sharing of experience with this would be greatly appreciated!!! This is really getting frustrating. Thanks much! Ken Johnson '83 FC 33 Midland, MI '83 FC Won't Start... - Curt Sprenger - 08-09-2005 14:52 Ken, FWIW...not sure about your unit, but I've had starter solenoids go bad and do this same kind of thing. If there is a starter solenoid attached to the started, tap on it lightly with a hammer. Try starting again. If this works then you need the solenoid. 12.55 volts at the starter should be okay. Could be the starter windings are failing. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. imgetnab2 wrote: > I'm still trying to find the culprit to my bus not starting. When I > turn it over, the engine briefly turns slowly, and then I get > the "da-da-da-da-da-da" of what sounds like dead batteries. I had > the batteries load tested, and they all failed, so I purchased 4 new > ones, and also replaced the battery cables in the battery > compartment. After replacement, I still get the same "weak battery" > response from the engine. I am measuring 12.55 volts at the starter, > and even when charging the batteries with the generator, I can't get > any different reaction from the engine... > > Am I missing something obvious that I need to check? I've also > checked the cable connections back by the door, and they seem to be > good. Are there other cable junctions that I may have missed, or > particular areas I should check? > > Any sharing of experience with this would be greatly appreciated!!! > This is really getting frustrating. > > Thanks much! > > Ken Johnson > '83 FC 33 > Midland, MI > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
