Rear Cruise Aire, Thanks to Ralph and Jeff - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Rear Cruise Aire, Thanks to Ralph and Jeff (/showthread.php?tid=1199) |
Rear Cruise Aire, Thanks to Ralph and Jeff - jesupbill - 08-16-2005 04:43 Rear cruiseaire is working. Thanks for all your help. Jeff Miller suggested that I check the overhead switch at the drivers seat. It was on however for some reason the toggle switch was bad. Thanks Bill Garlen 84PT40 Jesup, GA "Wink and a Smile" Rear Cruise Aire, Thanks to Ralph and Jeff - Ralph L. Fullenwider - 08-16-2005 05:48 That is good news Bill. That is where I was taking you as well after we found out about the power going to the terminal strip not being present. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:43 PM 8/16/2005 +0000, you wrote: >Rear cruiseaire is working. Thanks for all your help. Jeff Miller >suggested that I check the overhead switch at the drivers seat. It was >on however for some reason the toggle switch was bad. > > >Thanks >Bill Garlen >84PT40 >Jesup, GA >"Wink and a Smile" > > > |
