Compartment door lock latch - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Compartment door lock latch (/showthread.php?tid=1205) |
Compartment door lock latch - Ron & Patty - 08-19-2005 04:58 the latch that locks the compartment has broken off. This is the latch that turns with the key. Does anyone know where to get a replacement, and more importantly, how do you replace it? Seems like everything is rivited. Thank you..... Ron 85PT36 No. Ca. Compartment door lock latch - gregoryoconnor - 08-19-2005 16:56 Ron When I remove rivits I drill out the center by using a bit that is slightly larger than the bellybutton side of the rivit. If you have the parts just weld it greg 94pt40 SO California --- In WanderlodgeForum@yahoogroups.com, "Ron & Patty" wrote: > the latch that locks the compartment has broken off. This is the > latch that turns with the key. Does anyone know where to get a > replacement, and more importantly, how do you replace it? Seems like > everything is rivited. Thank you..... > > Ron 85PT36 No. Ca. |
