Suburban Heater Fan Motor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: Interior (/forumdisplay.php?fid=25) +--- Thread: Suburban Heater Fan Motor (/showthread.php?tid=122) |
Suburban Heater Fan Motor - csprenger - 02-27-2013 13:24 Two of our Suburban heaters (NT16SW) have squealing fan motors. Called Suburban at 423-775-2131. Was told the NT16SW is obsolete and was a special build for Wanderlodge. The standard build is the NT16 SE and can be found on the internet, etc. However, fan motor kit 520949 is available for the SW furnace. It replaces 232877. The kit includes the two gaskets. The 520949 Internet prices vary from mid $60.00s to way up. http://www.americanrvcompany.com/Sub...RV_p_1335.html I ordered two fan motors. Yesterday, completed the fan motor R&R on one of the heaters. The new motor works great. Looks to be a bearing at each end. The old motor was hard to rotate and binding, bad bushing perhaps. RE: Suburban Heater Fan Motor - Itchintogo - 02-27-2013 14:27 That is great to know Curt. Thanks! I probably have the same Heaters. All of mine work fine so far except the kitchen one. But it just needs a little cleaning from spending time in the desert. RE: Suburban Heater Fan Motor - csprenger - 02-27-2013 14:37 (02-27-2013 14:27)Itchintogo Wrote: That is great to know Curt. Thanks! I probably have the same Heaters. All of mine work fine so far except the kitchen one. But it just needs a little cleaning from spending time in the desert. I believe our previous Bird, 1974, had the same heaters. They were a part of BB building for many years. RE: Suburban Heater Fan Motor - csprenger - 03-03-2013 20:37 Today, completed the 2nd Suburban Propane Heater fan motor R&R. All is good. This heater is under the stacked drawers between the bath and bed. The copper propane line that connects the heater to the feed line on top of the heater was replaced with a rubber hose, making it easy to hook up to the feed line. Next, going to take a look at the propane detector. I believe it's original and I doubt it's working. Time for another R&R. |
