engine removal - Printable Version
+--- Forum: General (/forumdisplay.php?fid=37)
+--- Thread: engine removal (/showthread.php?tid=12351)
engine removal - britten44 - 04-05-2026 17:20
I have a mechanic that is going to help me remove the 3208T from my 1988 FC35. It spun a bearing and needs to be rebuilt. Can any provide some step by step instructions or advice? I am assuming that I will drop the engine and trans out the bottom and slide it out the front??
Thanks for any help!
Doug
RE: engine removal - Arcticdude - 04-07-2026 18:03
Doug,
IIRC, you pull the front end (bumper, grill, etc), then either pull the radiator assembly or swing it open (if that Bird has a swing radiator) and then pull the engine straight out the front.
Many folks put in a swing radiator just for better access to the engine front, if yours doesn't have it.
