oil pressure sender - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: oil pressure sender (/showthread.php?tid=1269) |
oil pressure sender - mjzakowski - 08-31-2005 12:12 My sender is working irradicly and would like to know where I can find a new one? Also I would like to know what temperature the engine oil should read when running the highway in a 6v92? Joe from IN with a 1984 1/2 pt40 oil pressure sender - Neil & Pat LeKander - 08-31-2005 12:37 Jo, I also have a 6V92 in a PT-36. I note that my oil temp generally runs just slightly over the water temp; that makes sense when you consider that the oil cooler is a oil to water heat exchanger. On hills or hard pulls I have observed an oil temp increase approximately in unison with the water temp climb. Regards, Neil My sender is working irradicly and would like to know where I can find a new one? Also I would like to know what temperature the engine oil should read when running the highway in a 6v92? [Non-text portions of this message have been removed] oil pressure sender - mjzakowski - 09-28-2005 13:17 Does any body out there know any thing about the oil pressure sender. It works for about 100 mile and than nothing. It is on a 1984 1/2 6v92 Does any body have a part Number or know where I can get one? Joe from IN 1984 1/2 PT 40 oil pressure sender - Howard O. Truitt - 09-29-2005 01:45 Joe, I would be very careful until getting the engine checked to be sure it is not the engine itself that is causing the drop in oil pressure. Anything below about 25 #'s oil pressure when cruising needs checking. Look for a Detroit Diesel dealer in your area. Or call Earl Davis at Bluebird Parts 1-800-495-7787 Howard Truitt 1986, PT40, 8V92 ----- Original Message ----- From: mjzakowski To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, September 28, 2005 9:17 PM Subject: [WanderlodgeForum] oil pressure sender Does any body out there know any thing about the oil pressure sender. It works for about 100 mile and than nothing. It is on a 1984 1/2 6v92 Does any body have a part Number or know where I can get one? Joe from IN 1984 1/2 PT 40 SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] oil pressure sender - mjzakowski - 09-30-2005 02:50 Hello I have new engine put in the bird before I brought it. It has less than 20,000. miles on it now. If the oil pump works when it is cold and shows pressure and still shows pressure after it gets to running temperature, Why would the pressure gage go down to zero reading after driving hour to hour and half? Also I did detected a slight oil leak at the sender unit. Do you think this might be the problem? Joe in IN 1984 1/2 pt 40 6v92 oil pressure sender - hjd3694 - 10-14-2005 06:22 --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@j...> wrote: > > Does any body out there know any thing about the oil pressure sender. > It works for about 100 mile and than nothing. It is on a 1984 1/2 6v92 > Does any body have a part Number or know where I can get one? > Joe from IN > 1984 1/2 PT 40 >I recently had the oil pressure guage go out. BB replaced the guage and it still didn't work. Then they replaced th sending unit. Didn't work. After a lot of consulting, they determined that the sending unit and guage have to be replaced in matching pairs. They were very fair in that they adjusted the labor as they figured it took too long to figure it out. {'92 WLWB, 8V92) Hope this helps |
