low coolant warning light is on during warm-up - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: low coolant warning light is on during warm-up (/showthread.php?tid=1283) |
low coolant warning light is on during warm-up - luckyron1 - 09-04-2005 04:43 2000 lxi w/500 hp D-60. I just had the coolant flushed and refilled in the spring of last yr. I've looked under the engine shroud and can't figure out where to add a 50/50 solution of diesel antifreeze/water. I don't see a plastic radiater overflow/reservoir tank or what you'd expect to see under the hood of a car and for that reason I don't even know how much to add. Where do I put the the fluid in and how much do I put in? Thanks. low coolant warning light is on during warm-up - g_man1146 - 09-04-2005 05:20 Hi Ron, If yours is the same as my '99LXi, the coolant fill "door" (about 5" square) is on the rear, above the engine compartment door, just left of center. You can access it with the engine compartment either open or closed, an angled funnel is helpful. The coolant reservoir itself is in the engine compartment, top center and has a sight glass to indicate full. On mine the coolant is only visible when warm and adding extra will result in expelling it through the overflow when hot. Fill until it just shows in the sight glass and your low-coolant light should go out. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > 2000 lxi w/500 hp D-60. I just had the coolant flushed and refilled in > the spring of last yr. I've looked under the engine shroud and can't > figure out where to add a 50/50 solution of diesel antifreeze/water. I > don't see a plastic radiater overflow/reservoir tank or what you'd > expect to see under the hood of a car and for that reason I don't even > know how much to add. Where do I put the the fluid in and how much do > I put in? Thanks. low coolant warning light is on during warm-up - John Suter - 09-04-2005 06:46 When you raise the engine cover compartment the opening is concealed by the cover. It's in the center, left to right. John Suter 2000LXi --- luckyron1 > 2000 lxi w/500 hp D-60. I just had the coolant > flushed and refilled in > the spring of last yr. I've looked under the engine > shroud and can't > figure out where to add a 50/50 solution of diesel > antifreeze/water. I > don't see a plastic radiater overflow/reservoir tank > or what you'd > expect to see under the hood of a car and for that > reason I don't even > know how much to add. Where do I put the the fluid > in and how much do > I put in? Thanks. > > > __________________________________ Do you Yahoo!? Yahoo! Mail - You care about security. So do we. http://promotions.yahoo.com/new_mail low coolant warning light is on during warm-up - R J - 09-04-2005 11:39 Thank you John Suter and G man. Coming from 2 lxi guys this has to be good advice. I'm looking at this from my poor email connection via my yahoo mailbox so I'll try to get this out. Can't get to the forum. By the way John, a few months back you helped me on the problem with the ceiling spotters. I have the solution if you still need it. Thanks again. --- g_man1146 > Hi Ron, > > If yours is the same as my '99LXi, the coolant fill > "door" (about 5" > square) is on the rear, above the engine compartment > door, just left of > center. You can access it with the engine > compartment either open or > closed, an angled funnel is helpful. The coolant > reservoir itself is in > the engine compartment, top center and has a sight > glass to indicate > full. On mine the coolant is only visible when warm > and adding extra > will result in expelling it through the overflow > when hot. Fill until > it just shows in the sight glass and your > low-coolant light should go > out. > > Rich D. '99LXi43' CT > > > > --- In WanderlodgeForum@yahoogroups.com, "luckyron1" > > wrote: > > 2000 lxi w/500 hp D-60. I just had the coolant > flushed and refilled > in > > the spring of last yr. I've looked under the > engine shroud and can't > > figure out where to add a 50/50 solution of diesel > antifreeze/water. > I > > don't see a plastic radiater overflow/reservoir > tank or what you'd > > expect to see under the hood of a car and for that > reason I don't > even > > know how much to add. Where do I put the the > fluid in and how much > do > > I put in? Thanks. > > > > |
