Would This Work - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Would This Work (/showthread.php?tid=1331) |
Would This Work - trvlngnrs - 09-15-2005 16:14 I have a set of 18 volt battery powered tools. Can I use this, or a smaller 12 volt battery to test different circuits? What I am thinking of, is connecting jumper wires to the wires at the circuit breaker (TV antenna for example) and connecting/touching the other ends to the 18 volt battery terminals. This way I could determine if the problem was before or after the breaker. Is my thinking flawed? Would using 18 volts damage anything? Steve Harrie Trying to Save a Few Steps Would This Work - trvlngnrs - 09-16-2005 01:52 > I have a set of 18 volt battery powered tools. Can I use this, or a smaller 12 volt battery to test different circuits? OK, thanks to those who contacted me off line. I wont use an 18 volt battery to test anything. The reason it ran across my mind, is on my old Dutch Star I had automatic awnings. At one time I couldn't get them to roll up. Care Free told me to use my 18 volt battery to give it more oomph, and I was able to close it. Thanks again for preventing a meltdown. Steve Harrie Would This Work - Scott Williams - 09-16-2005 12:34 Steve, Send me an email & I'll give you my phone no. If you still need help you can call & I'll help you trouble shoot nthe electrical on your antenna. Scott Williams SOB ======== --- In WanderlodgeForum@yahoogroups.com, "trvlngnrs" wrote: > I have a set of 18 volt battery powered tools. Can I use this, or a > smaller 12 volt battery to test different circuits? What I am thinking > of, is connecting jumper wires to the wires at the circuit breaker (TV > antenna for example) and connecting/touching the other ends to the 18 > volt battery terminals. This way I could determine if the problem was > before or after the breaker. > > Is my thinking flawed? > Would using 18 volts damage anything? > > Steve Harrie > Trying to Save a Few Steps |
