Postive / Negative ground system - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Postive / Negative ground system (/showthread.php?tid=1343) |
Postive / Negative ground system - transit360 - 09-17-2005 07:38 I have two Bluebird QBRE's and they are wired a little diffently. In short, how can I tell if someone has wired one bus or the other for a positive or negative ground system? Please only advise if you can supply me with some tests I can run with a meter or if you've had experience with electrical systems. I'm running inverters and they've warned NOT to use these with a positive ground system. The reason I ask is because there is a + and - terminal on the battery hooked likewise to the alternator. Then I have a 3rd wire, probably 6 gauge that runs to the starter. NOW, on the 1st bus this 3rd wire runs from the + on the alternator to the starter SOLENOID, where is shares a main + feed from the battery. On the 2nd bus, this same wire runs from the - side of the alternator to a ground stud of the back of the starter BODY, where is shares this stud with a main ground strap. Is this a postive ground system? I only discovered this after on the 2nd bus I hooked this wire to the + side of the alternator to match the other bus, only to have it heat up. I didn't know why until I traced the wire to the ground stud on the starter body. Would anyone know of any reason why a mechanic would do this, especially on two identical buses? And more importantly, how can I wire this system up to guarantee that it's the typical negative ground system that I need? Or is this system still a negative ground anyways?? I have a little electrical knowledge but I'm stumped and I really don't want to damage my new inverters. Thanks, Steve Two '98 Bluebird QBRE Partybuses Postive / Negative ground system - Scott Peatross - 09-17-2005 13:42 Sounds like they are both negative ground systems. The "ground" of a system is determined by which terminal of the battery is connected to the frame/body/engine. So in a negative ground system, the negative side of the battery is connected to the frame, and all positive connections must be isolated from the frame. Notice that one alternator has the 3rd wire positive to positive, the other has the third wire negative to negative. No problem there. Does the 2nd alternator have anything connected to the positive connection? Scott Peatross '87 PT40 --- transit360 --------------------------------- I have two Bluebird QBRE's and they are wired a little diffently. In short, how can I tell if someone has wired one bus or the other for a positive or negative ground system? Please only advise if you can supply me with some tests I can run with a meter or if you've had experience with electrical systems. I'm running inverters and they've warned NOT to use these with a positive ground system. The reason I ask is because there is a + and - terminal on the battery hooked likewise to the alternator. Then I have a 3rd wire, probably 6 gauge that runs to the starter. NOW, on the 1st bus this 3rd wire runs from the + on the alternator to the starter SOLENOID, where is shares a main + feed from the battery. On the 2nd bus, this same wire runs from the - side of the alternator to a ground stud of the back of the starter BODY, where is shares this stud with a main ground strap. Is this a postive ground system? I only discovered this after on the 2nd bus I hooked this wire to the + side of the alternator to match the other bus, only to have it heat up. I didn't know why until I traced the wire to the ground stud on the starter body. Would anyone know of any reason why a mechanic would do this, especially on two identical buses? And more importantly, how can I wire this system up to guarantee that it's the typical negative ground system that I need? Or is this system still a negative ground anyways?? I have a little electrical knowledge but I'm stumped and I really don't want to damage my new inverters. Thanks, Steve Two '98 Bluebird QBRE Partybuses SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Postive / Negative ground system - steve wicker - 09-17-2005 20:01 The 2nd alternator does not have anything attached to the positive alternator terminal but the positive battery cable. There's only 3 wires to each alternator. A definate positive and negative cable from the battery to alternator, and the 3rd smaller wire. Steve Scott Peatross <slpeatross@...> wrote: Sounds like they are both negative ground systems. The "ground" of a system is determined by which terminal of the battery is connected to the frame/body/engine. So in a negative ground system, the negative side of the battery is connected to the frame, and all positive connections must be isolated from the frame. Notice that one alternator has the 3rd wire positive to positive, the other has the third wire negative to negative. No problem there. Does the 2nd alternator have anything connected to the positive connection? Scott Peatross '87 PT40 --- transit360 --------------------------------- I have two Bluebird QBRE's and they are wired a little diffently. In short, how can I tell if someone has wired one bus or the other for a positive or negative ground system? Please only advise if you can supply me with some tests I can run with a meter or if you've had experience with electrical systems. I'm running inverters and they've warned NOT to use these with a positive ground system. The reason I ask is because there is a + and - terminal on the battery hooked likewise to the alternator. Then I have a 3rd wire, probably 6 gauge that runs to the starter. NOW, on the 1st bus this 3rd wire runs from the + on the alternator to the starter SOLENOID, where is shares a main + feed from the battery. On the 2nd bus, this same wire runs from the - side of the alternator to a ground stud of the back of the starter BODY, where is shares this stud with a main ground strap. Is this a postive ground system? I only discovered this after on the 2nd bus I hooked this wire to the + side of the alternator to match the other bus, only to have it heat up. I didn't know why until I traced the wire to the ground stud on the starter body. Would anyone know of any reason why a mechanic would do this, especially on two identical buses? And more importantly, how can I wire this system up to guarantee that it's the typical negative ground system that I need? Or is this system still a negative ground anyways?? I have a little electrical knowledge but I'm stumped and I really don't want to damage my new inverters. Thanks, Steve Two '98 Bluebird QBRE Partybuses SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- Steve Wicker http://www.360partybus.com 828-236-2841/301-0245 __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] Postive / Negative ground system - bluebirdsp36 - 09-18-2005 07:57 Steve, I also have two 1995 QBREs with consecutive VIN #s. I'm converting one and have the other for sale. Mine are both negetive grounds. All the documentation I have I will share with you. . . Wiring diagrams, fault code charts, operator's manual, drive train manual, etc.. I just checked my wiring schematic which covers models through 1999 and all are neg gnd. Paul Cunningham Virginia 1990 SP-36 & Two Q-Busses --- In WanderlodgeForum@yahoogroups.com, "transit360" > I have two Bluebird QBRE's and they are wired a little diffently. > Thanks, > Steve > Two '98 Bluebird QBRE Partybuses Postive / Negative ground system - Tom Warner - 09-18-2005 12:03 You have a negative ground system. As far as I know Bluebird never made a postive ground electrical system. You should have a red wire attached to the Plus terminal of your alternator and going to either the positive terminal of your battery or the positive terminal insulated fromo the chassis and then to the Plus terminal of the battery. The black wire is attached to the minus(negative( terminal of the alternator and then to ground. Sometimes it goes to a stud on the starter and then a ground braid to the chassis. The third wire is probably a sense wire and goes from the internal voltage regulator stud on the outside of the alternator and then to the positive battery terminal. It senses the true voltage from the battery and NOT the voltage across the positive and negative terminals of the alternator. tom 1982 FC35 Vernon Center,NY At 04:01 AM 9/18/2005, you wrote: > The 2nd alternator does not have anything attached to the > positive alternator terminal but the positive battery cable. > There's only 3 wires to each alternator. A definate positive and > negative cable from the battery to alternator, and the 3rd smaller wire. > >Steve > >Scott Peatross <slpeatross@...> wrote: >Sounds like they are both negative ground systems. The >"ground" of a system is determined by which terminal >of the battery is connected to the frame/body/engine. >So in a negative ground system, the negative side of >the battery is connected to the frame, and all >positive connections must be isolated from the frame. > >Notice that one alternator has the 3rd wire positive >to positive, the other has the third wire negative to >negative. No problem there. Does the 2nd alternator >have anything connected to the positive connection? > >Scott Peatross >'87 PT40 > >--- transit360 > > >--------------------------------- > I have two Bluebird QBRE's and they are wired a >little diffently. >In short, how can I tell if someone has wired one bus >or the other >for a positive or negative ground system? Please only >advise if you >can supply me with some tests I can run with a meter >or if you've >had experience with electrical systems. I'm running >inverters and >they've warned NOT to use these with a positive ground >system. > The reason I ask is because there is a + and - >terminal on the >battery hooked likewise to the alternator. Then I have >a 3rd wire, >probably 6 gauge that runs to the starter. > NOW, on the 1st bus this 3rd wire runs from the >+ on the >alternator to the starter SOLENOID, where is shares a >main + feed >from the battery. > On the 2nd bus, this same wire runs from the - >side of the >alternator to a ground stud of the back of the starter >BODY, where >is shares this stud with a main ground strap. Is this >a postive >ground system? > I only discovered this after on the 2nd bus I >hooked this >wire to the + side of the alternator to match the >other bus, only to >have it heat up. I didn't know why until I traced the >wire to the >ground stud on the starter body. > Would anyone know of any reason why a mechanic >would do this, >especially on two identical buses? And more >importantly, how can I >wire this system up to guarantee that it's the typical >negative >ground system that I need? Or is this system still a >negative ground >anyways?? I have a little electrical knowledge but I'm >stumped and I >really don't want to damage my new inverters. > >Thanks, >Steve >Two '98 Bluebird QBRE Partybuses > > > > > > SPONSORED LINKS > >Recreational vehicles > Wanderlodge >Automotive maintenance > Recreational vehicle >dealer Used >recreational vehicles > Automotive radiators > > >--------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! >Terms of Service. > > >--------------------------------- > > > > > >SPONSORED LINKS >Recreational vehicles Wanderlodge Automotive maintenance >Recreational vehicle dealer Used recreational vehicles Automotive radiators > >--------------------------------- >YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > >--------------------------------- > > > > >Steve Wicker >http://www.360partybus.com >828-236-2841/301-0245 > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around ><http://mail.yahoo.com>http://mail.yahoo.com > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Postive / Negative ground system - steve wicker - 09-19-2005 04:03 That all sound right except that my 3rd wire is about a 4 gauge and on one bus it goes from + on alternator to + on starter solenoid and on the other bus it goes from - on alternator to a ground on the back of the starter body, which shares a terminal with a ground strap. Thanks for the info. I'm learning! Also, one bus is wired with an exciter wire and the other had the alternator rebuilt so that it doesn't need the exciter wire anymore, but the exciter wire is really small compared to the 3rd mystery wire. Steve Tom Warner You have a negative ground system. As far as I know Bluebird never made a postive ground electrical system. You should have a red wire attached to the Plus terminal of your alternator and going to either the positive terminal of your battery or the positive terminal insulated fromo the chassis and then to the Plus terminal of the battery. The black wire is attached to the minus(negative( terminal of the alternator and then to ground. Sometimes it goes to a stud on the starter and then a ground braid to the chassis. The third wire is probably a sense wire and goes from the internal voltage regulator stud on the outside of the alternator and then to the positive battery terminal. It senses the true voltage from the battery and NOT the voltage across the positive and negative terminals of the alternator. tom 1982 FC35 Vernon Center,NY Steve Wicker http://www.360partybus.com 828-236-2841/301-0245 --------------------------------- Yahoo! for Good Click here to donate to the Hurricane Katrina relief effort. [Non-text portions of this message have been removed] |
