Hot water heater troubleshooting - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Hot water heater troubleshooting (/showthread.php?tid=1401) |
Hot water heater troubleshooting - bascom1968 - 09-30-2005 16:39 The engine heats the water, but turning on the breaker after parking does not result in hot water. I am getting ready to start looking for the problem. Any suggestions of things to check and in what order, would be appreciated. Thanks, JB Lewis, 77FC31, Grand Lake,Ok. Hot water heater troubleshooting - rwoodysurplus - 09-30-2005 23:39 ck for elec at the probes..like a regular heater at home..if you have power then you have a element burnt out!~ if not thermosat or breaker pop-ed? woody 81fcrb --- In WanderlodgeForum@yahoogroups.com, "bascom1968" wrote: > The engine heats the water, but turning on the breaker after parking > does not result in hot water. I am getting ready to start looking for > the problem. Any suggestions of things to check and in what order, > would be appreciated. Thanks, JB Lewis, 77FC31, Grand Lake,Ok.ker Hot water heater troubleshooting - Tom Warner - 10-01-2005 01:27 There is also a safety device that will not allow the heater to go on if the water is to low in the tank. tom 1982 FC35 Vernon Center,NY At 07:39 AM 10/1/2005, you wrote: >ck for elec at the probes..like a regular heater at home..if you have >power then you have a element burnt out!~ > >if not thermosat or breaker pop-ed? > >woody 81fcrb > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "bascom1968" >wrote: > > The engine heats the water, but turning on the breaker after parking > > does not result in hot water. I am getting ready to start looking for > > the problem. Any suggestions of things to check and in what order, > > would be appreciated. Thanks, JB Lewis, 77FC31, Grand Lake,Ok.ker > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Hot water heater troubleshooting - putneyflash - 10-01-2005 13:03 make sure breaker is on, switch is red (on) on the back of the heater is a cover held on with two screws, kill power take them out you will see thermostat on the bottom, be careful with power on,check for voltage at the top screw, if voltage present at top screw but not bottom, elememt is shot. if not back up to thermostat or eco switch all should pass votage to element. bb sells for 28.00 at home depot they have an adaper that will adapt from the 4 hole flange into a screw in type elemnet adapter and element is about $15.00. orr and orr sells a 4 bolt elemnt for about $9.50 re brake -- In WanderlodgeForum@yahoogroups.com, "bascom1968" wrote: > The engine heats the water, but turning on the breaker after parking > does not result in hot water. I am getting ready to start looking for > the problem. Any suggestions of things to check and in what order, > would be appreciated. Thanks, JB Lewis, 77FC31, Grand Lake,Ok. Hot water heater troubleshooting - bascom1968 - 10-01-2005 15:55 Found the problem. An unmarked wall switch in the bedroom controls the tank! Happy to find this before tearing the tank apart. Thanks for suggestions. --- In WanderlodgeForum@yahoogroups.com, "bascom1968" wrote: > The engine heats the water, but turning on the breaker after parking > does not result in hot water. I am getting ready to start looking for > the problem. Any suggestions of things to check and in what order, > would be appreciated. Thanks, JB Lewis, 77FC31, Grand Lake,Ok. |
