Problems with Dometic RM2820 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Problems with Dometic RM2820 (/showthread.php?tid=1417) |
Problems with Dometic RM2820 - racin41@... - 10-05-2005 00:50 Bill, Hope you have better luck with your Dometic!! Ours was professionally installed, very solid, with good clearance. We have only driven about 8k miles since purchase of refrigerator. This is of course with air suspension, which should dampen vibration. The unit looks like it was just installed. The Dometic warranty covers a three-year period--our failed in four years. The original unit lasted 15 years (factory demo built in 1986). Bill & Rita in Roanoke, VA 1987 FC-35 with DEAD DOMETIC [Non-text portions of this message have been removed] Problems with Dometic RM2820 - racin41bb - 10-05-2005 03:24 We purchased a Dometic RM2820 refrigerator in July, 2001. Yesterday the coolant system began leaking. Not much of a life for a $1200 unit. If you replace your refrigerator with this model get the extended warranty. Bill & Rita in Roanoke, VA 1987 FC-35 Problems with Dometic RM2820 - pattypape - 10-05-2005 04:31 Bill, This is not good news, I just installed a RM 2820. It is really a tight fit. Do you think the cooling tubes could be rubbing or vibrating against the rear wall?? Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "racin41bb" wrote: > We purchased a Dometic RM2820 refrigerator in July, 2001. Yesterday > the coolant system began leaking. Not much of a life for a $1200 > unit. If you replace your refrigerator with this model get the > extended warranty. > > Bill & Rita in Roanoke, VA > 1987 FC-35 Problems with Dometic RM2820 - Tom Warner - 10-05-2005 05:10 I am not Bill but I can tell you what happened when I installed mine. The space that bluebird had installed the original Reefer in did not conform to the design that Dometic specified in their brochure. I had to completely rebuild it. I believe that is why they installed a fan in the back to get it to work. The slide in toaster in the kitchen protruded into the space that normally would flow air thru the coils so I removed it. The coils themselves must be fairly close to the rear wall and the sides of the reefer must be insulated good and be a tight fit. There also has to be an air damn installed on the top of the reefer to stop hot air from "pooling" at the top and not flow out the roof vent. Mine now works excellent. tom 1982 Fc35 Vernon Center,NY At 12:31 PM 10/5/2005, you wrote: >Bill, > >This is not good news, I just installed a RM 2820. >It is really a tight fit. Do you think the cooling tubes could be >rubbing or vibrating against the rear wall?? > >Bill 88 FC > > > >--- In WanderlodgeForum@yahoogroups.com, "racin41bb" >wrote: > > We purchased a Dometic RM2820 refrigerator in July, 2001. Yesterday > > the coolant system began leaking. Not much of a life for a $1200 > > unit. If you replace your refrigerator with this model get the > > extended warranty. > > > > Bill & Rita in Roanoke, VA > > 1987 FC-35 > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreationa\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Problems with Dometic RM2820 - John B. Montgomery, AIA - 10-05-2005 06:39 Thanks for the advice. John B. Montgomery, AIA, CSI, RAS Architect & Accessibility Specialist P. O. Box 209 Riverside, Texas 77367-0209 Phone: 936-594.6049 Cell: 936-577.2426 Fax: 936-594.0839 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of racin41bb Sent: Wednesday, October 05, 2005 10:24 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Problems with Dometic RM2820 We purchased a Dometic RM2820 refrigerator in July, 2001. Yesterday the coolant system began leaking. Not much of a life for a $1200 unit. If you replace your refrigerator with this model get the extended warranty. Bill & Rita in Roanoke, VA 1987 FC-35 _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] Problems with Dometic RM2820 - martingregg598 - 10-05-2005 10:25 Bill & Rita, I would ask Dometic if they would consider extending the warranty on your unit. Many times a manufacure will work with the customer. It never hurts to ask. Marty 95 BMC - In WanderlodgeForum@yahoogroups.com, "racin41bb" wrote: > We purchased a Dometic RM2820 refrigerator in July, 2001. Yesterday > the coolant system began leaking. Not much of a life for a $1200 > unit. If you replace your refrigerator with this model get the > extended warranty. > > Bill & Rita in Roanoke, VA > 1987 FC-35 Problems with Dometic RM2820 - racin41@... - 10-05-2005 19:41 Marty, Thanks for the reply. Dometic declined any help with the replacement cost because the refrigerator had been out of warranty for a year. I'll give them a call a regarding extending the warranty. Thanks again, Bill in Roanoke, VA (68 & rain) 1987 FC-35 [Non-text portions of this message have been removed] Problems with Dometic RM2820 - Jack & Donna Smith - 10-07-2005 05:00 Our Dometic gave up the ghost on the 3rd day of a two mounth trip. Not wishing to return home, or spend our traveling money for a new unit, we stopped st Home Depot, and bought a two+ cubic foot 'bartype refidgerator. We used a motorcycle tie down and strapped it to the dinette table, and "Made Do" for the rest of the trip. After returning home, we went to the RV store, and lucked out, because they had a 2 year old "TakeOut" unit which they installed for a good price.. Jack & Donna Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, "racin41bb" > > We purchased a Dometic RM2820 refrigerator in July, 2001. Yesterday > the coolant system began leaking. Not much of a life for a $1200 > unit. If you replace your refrigerator with this model get the > extended warranty. > > Bill & Rita in Roanoke, VA > 1987 FC-35 > |
