Gencon on LXi - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Gencon on LXi (/showthread.php?tid=1438) |
Gencon on LXi - David Brady - 10-13-2005 10:41 Folks, I'm having Westhaver Associates take a look at my gencon board to check for general health and to calibrate it to a new AC adapter. In the process, Larry noticed that with a high probability, the board is running incorrect software. The board, as delivered by blue bird, is assuming an 89 tooth flywheel, and Larry is pretty sure that the 15kw Powertech generator uses a 110 tooth flywheel. Anyone know off the top of their head whether the 15 kw Powertech in an '02 LXi uses an 89 or a 110 tooth flywheel? Thanks David '02 LXi, Smokey, Va -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.344 / Virus Database: 267.11.14/131 - Release Date: 10/12/2005 Gencon on LXi - Scott - 10-13-2005 12:18 Hello David, If I were in your situation I would get it from the horses mouth...contact Service Manager - Corey Bulleman - Service@... HE is the guy that would know. I found him to be extremely knowledgeable about their products. Very nice guy..Try that maybe you can get the info quickly. Scott B 86FC35 "RUBY" Murrells Inlet SC --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Folks, > > I'm having Westhaver Associates take a look > at my gencon board to check for general health > and to calibrate it to a new AC adapter. In > the process, Larry noticed that with a high > probability, the board is running incorrect software. > The board, as delivered by blue bird, is assuming > an 89 tooth flywheel, and Larry is pretty sure that > the 15kw Powertech generator uses a 110 tooth > flywheel. Anyone know off the top of their head > whether the 15 kw Powertech in an '02 LXi uses > an 89 or a 110 tooth flywheel? > > Thanks > David > '02 LXi, Smokey, Va > > > -- > No virus found in this outgoing message. > Checked by AVG Anti-Virus. > Version: 7.0.344 / Virus Database: 267.11.14/131 - Release Date: 10/12/2005 > Gencon on LXi - Scott - 10-13-2005 13:08 David, Feel free to use my name he will remember me..Heck we were buddies for a week I had coffee for him when they showed up at 7:00am..we talked about the auto feature for the genset they installed but I decided "nahh" not for us..Good luck..he is a really nice/knowledgeable guy. Scott B 86FC35 "RUBY" Murrells Inlet SC - In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Thanks for the contact Scott, I'll call Corey > in the morning - mind if I mention your name? > BTW, I don't know if you're familiar with the > gencon product. If not, you can find info about > it here (NFI): > > http://www.westhaverassociates.com > > It's pretty much standard issue on later coaches. > Basically it monitors the battery voltage levels and > starts and stops the generator automatically. May > be just the thing for your new generator. Now that > you have everything fixed on your coach, you may > be looking for new toys to tinker with. > > See you in Perry, > David and Suzy > '02 LXi, Smokey, Va > > Scott wrote: > > >Hello David, If I were in your situation I would get it from the > >horses mouth...contact > > > >Service Manager - Corey Bulleman - Service@P... > > > >HE is the guy that would know. I found him to be extremely > >knowledgeable about their products. Very nice guy..Try that maybe you > >can get the info quickly. > > > >Scott B > >86FC35 "RUBY" > >Murrells Inlet SC > > > >--- In WanderlodgeForum@yahoogroups.com, David Brady > >wrote: > > > > > >>Folks, > >> > >>I'm having Westhaver Associates take a look > >>at my gencon board to check for general health > >>and to calibrate it to a new AC adapter. In > >>the process, Larry noticed that with a high > >>probability, the board is running incorrect software. > >>The board, as delivered by blue bird, is assuming > >>an 89 tooth flywheel, and Larry is pretty sure that > >>the 15kw Powertech generator uses a 110 tooth > >>flywheel. Anyone know off the top of their head > >>whether the 15 kw Powertech in an '02 LXi uses > >>an 89 or a 110 tooth flywheel? > >> > >>Thanks > >>David > >>'02 LXi, Smokey, Va > >> > >> > >>-- > >>No virus found in this outgoing message. > >>Checked by AVG Anti-Virus. > >>Version: 7.0.344 / Virus Database: 267.11.14/131 - Release Date: > >> > >> > >10/12/2005 > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > No virus found in this outgoing message. > Checked by AVG Anti-Virus. > Version: 7.0.344 / Virus Database: 267.11.14/131 - Release Date: 10/12/2005 > Gencon on LXi - David Brady - 10-13-2005 13:11 Thanks for the contact Scott, I'll call Corey in the morning - mind if I mention your name? BTW, I don't know if you're familiar with the gencon product. If not, you can find info about it here (NFI): http://www.westhaverassociates.com It's pretty much standard issue on later coaches. Basically it monitors the battery voltage levels and starts and stops the generator automatically. May be just the thing for your new generator. Now that you have everything fixed on your coach, you may be looking for new toys to tinker with. See you in Perry, David and Suzy '02 LXi, Smokey, Va Scott wrote: >Hello David, If I were in your situation I would get it from the >horses mouth...contact > >Service Manager - Corey Bulleman - Service@... > >HE is the guy that would know. I found him to be extremely >knowledgeable about their products. Very nice guy..Try that maybe you >can get the info quickly. > >Scott B >86FC35 "RUBY" >Murrells Inlet SC > >--- In WanderlodgeForum@yahoogroups.com, David Brady >wrote: > > >>Folks, >> >>I'm having Westhaver Associates take a look >>at my gencon board to check for general health >>and to calibrate it to a new AC adapter. In >>the process, Larry noticed that with a high >>probability, the board is running incorrect software. >>The board, as delivered by blue bird, is assuming >>an 89 tooth flywheel, and Larry is pretty sure that >>the 15kw Powertech generator uses a 110 tooth >>flywheel. Anyone know off the top of their head >>whether the 15 kw Powertech in an '02 LXi uses >>an 89 or a 110 tooth flywheel? >> >>Thanks >>David >>'02 LXi, Smokey, Va >> >> >>-- >>No virus found in this outgoing message. >>Checked by AVG Anti-Virus. >>Version: 7.0.344 / Virus Database: 267.11.14/131 - Release Date: >> >> >10/12/2005 > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.344 / Virus Database: 267.11.14/131 - Release Date: 10/12/2005 Gencon on LXi - David Brady - 10-14-2005 10:52 Folks, I managed to get in touch with Corey Bulleman at PowerTech. If anyone is interested, the '02 LXi Powertech generator uses a 4 cylinder kubota engine and the flywheel has 110 teeth. Sorry for this esoteric data, but I'm just closing the loop and providing something for the archives: Generator part no: PTSMH-15BB powertech serial no: KMA40DEA3320BB rated power: 17.5KW Thanks Scott. Corey asked how your genny conversion was working out. I assured him that based on your messages posted to this list, the conversion is working beautifully. He was pleased. Thanks again, David Brady '02 LXi, Smokey, Va >> Scott wrote: >>Service Manager - Corey Bulleman - Service@... >> >> -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.344 / Virus Database: 267.12.0/132 - Release Date: 10/13/2005 |
