Please help- what is this box for? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Please help- what is this box for? (/showthread.php?tid=1445) |
Please help- what is this box for? - sfedeli3 - 10-17-2005 01:20 Hello all, Since owning my 85PT40, I've wondered what the purpose of this white box is in the basement of the bird. (please see photos link and look at "What the heck is this" towards the end) It has no writing on it and a large 2ga. 12V wire going to it. Thought that it might be an iverter, but not sure. Does not appear to have any 110V wiring coming out of the other side. Any help would be greatly appreciated. Shane Fedeli 85PT40 Hershey, PA 55 degrees windy and sunny- October is here! Please help- what is this box for? - Ralph L. Fullenwider - 10-17-2005 01:33 Hi Shane: That box is the electronic filter unit. It has been moved from under the sofa to the bay. That is the unit that your master electronic switch in the over head compartment, drivers side, nearest the galley/salon area, controls. That filter stops the spurious noise put out and controls all your clocks timers, level panels and so forth in your coach. It is important, so don't remove it, just re locate it if it is in the way. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:20 PM 10/17/2005 +0000, you wrote: >Hello all, > Since owning my 85PT40, I've wondered what the purpose of this >white box is in the basement of the bird. (please see photos link and >look at "What the heck is this" towards the end) It has no writing on >it and a large 2ga. 12V wire going to it. Thought that it might be an >iverter, but not sure. Does not appear to have any 110V wiring coming >out of the other side. Any help would be greatly appreciated. > >Shane Fedeli >85PT40 >Hershey, PA > >55 degrees windy and sunny- October is here! > > > Please help- what is this box for? - Curt Sprenger - 10-17-2005 01:40 Shane, Is there a fan in one end? That white box looks like the battery chargers I removed from our 1987 PT38. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. sfedeli3 wrote: > Hello all, > Since owning my 85PT40, I've wondered what the purpose of this > white box is in the basement of the bird. (please see photos link and > look at "What the heck is this" towards the end) It has no writing on > it and a large 2ga. 12V wire going to it. Thought that it might be an > iverter, but not sure. Does not appear to have any 110V wiring coming > out of the other side. Any help would be greatly appreciated. > > Shane Fedeli > 85PT40 > Hershey, PA > > 55 degrees windy and sunny- October is here! > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > Please help- what is this box for? - sfedeli3 - 10-17-2005 10:30 Hi Ralph, Many, many thanks to you and also to Oene Pomper. Both of you indicated that it was a 12V noise filter. It's not in the way, but I'm a nut about knowing what things do and are for, so I had to ask. My digitell system never has worked, but the clocks, level meters and such all work fine, so I guess the unit is functioning as it should. Thanks again for the tip. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Hi Shane: > > That box is the electronic filter unit. It has been moved from under the > sofa to the bay. That is the unit that your master electronic switch in the > over head compartment, drivers side, nearest the galley/salon area, > controls. That filter stops the spurious noise put out and controls all > your clocks timers, level panels and so forth in your coach. It is > important, so don't remove it, just re locate it if it is in the way. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 01:20 PM 10/17/2005 +0000, you wrote: > >Hello all, > > Since owning my 85PT40, I've wondered what the purpose of this > >white box is in the basement of the bird. (please see photos link and > >look at "What the heck is this" towards the end) It has no writing on > >it and a large 2ga. 12V wire going to it. Thought that it might be an > >iverter, but not sure. Does not appear to have any 110V wiring coming > >out of the other side. Any help would be greatly appreciated. > > > >Shane Fedeli > >85PT40 > >Hershey, PA > > > >55 degrees windy and sunny- October is here! > > > > > > > |
