90sp36 Onan 3cyl dcd Genset - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 90sp36 Onan 3cyl dcd Genset (/showthread.php?tid=1479) |
90sp36 Onan 3cyl dcd Genset - williamcharrison - 10-24-2005 05:50 Hi all, I have tried suggestions from several folks re checking switches and presence of 12v at the stop solenoid. Switches are ok and the 12v required to operate the stop solenoid is present only when the start button is depressed. If I had a full schematic I could probably figure it out but I don't. Could the problem be an oil pressure sensor? 90sp36 Onan 3cyl dcd Genset - Henry Jay Hannigan - 10-24-2005 06:15 ---Again...I know it sounds simple but I had similar problem and air blew switches on jenny, then jiggled them on and off a few times and it worked. The long time sitting must have messed up my switch contacts.....that's all I know..up to RALPH after that! good luck, Hank Hannigan 90SP36 In WanderlodgeForum@yahoogroups.com, "williamcharrison" > > Hi all, > I have tried suggestions from several folks re checking switches and > presence of 12v at the stop solenoid. Switches are ok and the 12v > required to operate the stop solenoid is present only when the start > button is depressed. If I had a full schematic I could probably > figure it out but I don't. Could the problem be an oil pressure > sensor? > 90sp36 Onan 3cyl dcd Genset - Tom Warner - 10-24-2005 07:51 Look on your control box and get the number. With that someone may have a schematic ( I have a few for the control boxes but had to go back to Kohler to finally get the correct one for mine. . If you take the cover off the control box check the relays inside and get the numbers off those also. If it is anything like mine it has two bosch relays and a Potter blumfield KUP155-120. I have torn mine all apart and have derusted and painted it and completely rewiring it so it is at last reliable(I hope). Tom Warner 1982 FC35 Vernon Center,NY At 01:50 PM 10/24/2005, you wrote: >Hi all, >I have tried suggestions from several folks re checking switches and >presence of 12v at the stop solenoid. Switches are ok and the 12v >required to operate the stop solenoid is present only when the start >button is depressed. If I had a full schematic I could probably >figure it out but I don't. Could the problem be an oil pressure >sensor? > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- 90sp36 Onan 3cyl dcd Genset - williamcharrison - 10-24-2005 08:36 Hi Tom, The genset number is 8DKDF J3244BC. --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Look on your control box and get the number. With that someone may > have a schematic ( I have a few for the control boxes but had to go > back to Kohler to finally get the correct one for mine. . If you take > the cover off the control box check the relays inside and get the > numbers off those also. If it is anything like mine it has two bosch > relays and a Potter blumfield KUP155-120. I have torn mine all apart > and have derusted and painted it and completely rewiring it so it is > at last reliable(I hope). > > Tom Warner > 1982 FC35 > Vernon Center,NY > > At 01:50 PM 10/24/2005, you wrote: > >Hi all, > >I have tried suggestions from several folks re checking switches and > >presence of 12v at the stop solenoid. Switches are ok and the 12v > >required to operate the stop solenoid is present only when the start > >button is depressed. If I had a full schematic I could probably > >figure it out but I don't. Could the problem be an oil pressure > >sensor? > > > > > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
