Tire monitoring system - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Tire monitoring system (/showthread.php?tid=1480) |
Tire monitoring system - dspithaler@... - 10-24-2005 08:16 Hi All Has anyone ever heard of this monitoring system? I had a valve stem failure this past week and am thinking about one. I don't know about the way it is monitored through the caps that are screwed on the valve stems. What do you think? www. tirepressure monitor. com/# Remove the spaces Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] Tire monitoring system - enow626@... - 10-24-2005 19:22 Don, We have the system only it's not under pressure pros name. D------ Damon or ??. It's great - - - and expensive. About $600 for 6 MH tires and 4 toad tires. I luv the sense of security it gives me - - - - especially after we had a toad front flat and didn't know it. Could have ended up towing a ball of fire. It continually monitors pressure and each tire transmitter send a signal to the monitor every 5 minutes. Ed Nowokunski 95BMC37 [Non-text portions of this message have been removed] Tire monitoring system - enow626@... - 10-24-2005 20:26 Don, Here's the D----- web site. D is for Doran. I believe Doran is the manufacturer and sells to pressure pro. _http://www.doranmfg.com/tirepressuremonitors.htm_ (http://www.doranmfg.com/tirepressuremonitors.htm) Ed Nowokunski 95BMC37 [Non-text portions of this message have been removed] Tire monitoring system - dspithaler@... - 10-24-2005 22:03 In a message dated 10/25/2005 8:31:18 A.M. Eastern Daylight Time, enow626@... writes: Don, Here's the D----- web site. D is for Doran. I believe Doran is the manufacturer and sells to pressure pro. _http://www.doranmfg.com/tirepressuremonitors.htm_ (http://www.doranmfg.com/tirepressuremonitors.htm) Ed Nowokunski 95BMC37 Thanks Ed I see what you mean they are both the same& the same price Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] Tire monitoring system - dspithaler@... - 10-25-2005 01:44 In a message dated 10/25/2005 7:23:24 A.M. Eastern Daylight Time, enow626@... writes: Don, We have the system only it's not under pressure pros name. D------ Damon or ??. It's great - - - and expensive. About $600 for 6 MH tires and 4 toad tires. I luv the sense of security it gives me - - - - especially after we had a toad front flat and didn't know it. Could have ended up towing a ball of fire. It continually monitors pressure and each tire transmitter send a signal to the monitor every 5 minutes. Ed Nowokunski 95BMC37 Thanks Ed The one I saw is the same as yours. Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] |
