Stepwell Cover - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Stepwell Cover (/showthread.php?tid=1484) |
Stepwell Cover - patticake592000 - 10-27-2005 05:10 Cannot extend the cover with the button. Can use the button and pull manually. Will move out slowly. Hit button, release, pull by hand, hit button again, release, etc. etc. until it is out. Retacts beautifully, just hit button. What do I do and where do I start? Steve Gureasko 90PT40WLWB Ponchatoula, La. Stepwell Cover - ronmarabito2002 - 10-27-2005 05:41 Steve: Sounds like you have either an air restriction or leak in the line to that cylinder. Haven't had to access it, but I would think it is under the platform that moves. Don't think you can access from above, but you can look. I assume your air pressures are up. R.e. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@e...> wrote: > > Cannot extend the cover with the button. Can use the button and pull > manually. Will move out slowly. Hit button, release, pull by hand, hit > button again, release, etc. etc. until it is out. Retacts beautifully, > just hit button. What do I do and where do I start? > Steve Gureasko > 90PT40WLWB > Ponchatoula, La. > Stepwell Cover - mbulriss - 10-27-2005 05:53 Steve, You need to verify that your air pressure is full up before you tear into anything. Mike Bulriss 83 PT40 "Stagecoach" - For Sale 91 PT40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "patticake592000" <sgureasko@e...> wrote: > > Cannot extend the cover with the button. Can use the button and pull > manually. Will move out slowly. Hit button, release, pull by hand, hit > button again, release, etc. etc. until it is out. Retacts beautifully, > just hit button. What do I do and where do I start? > Steve Gureasko > 90PT40WLWB > Ponchatoula, La. > |
