Perkins Exaust Cooler - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Perkins Exaust Cooler (/showthread.php?tid=1498) |
Perkins Exaust Cooler - Jeff August - 10-29-2005 02:22 Has anyone ever removed the four bolts that hold the exaust to the unit? We need to replace the exaust but am afraid that removing them could open us up for another big problem. The threaded pipe used is so rusty it is not possible to take it apart in peices like it should be. Might have to cut it near the cooler and try and unthread the peice that goes in to the cooler? Thankyou for any help! Jeff & Michelle August 1980 FC35RB Plymouth Wi Perkins Exaust Cooler - Tom Warner - 10-29-2005 02:36 I have not done it ........YET. Mine is still in nice shape. However if I were going to do it I would use the method that has always worked for me on other connections like this. Here is the procedure I use that has worked for me on some very tough rusted connections like you describe. 1. Clean the connection with a wire brush (I use a circular one that fits my high speed die grinder) and get as much rust off the fittings where they go together. This gives the solvent ( PB blaster) the best chance to penetrate the connections. 2. If you have a small propane torch (I find that my acetylene torch is better) heat up the joint good (the outer connection) so that it expands a little. Then spray the PB blaster on it at the same time rapping it gently with a ball peen hammer. Don't get aggressive with it, its not necessary. Do this a few times and try to get the connection to come loose each time but DON'T use a lot of force. Gently do it and it will come loose. Tom Warner 1982 FC35 Vernon Center,NY At 10:22 AM 10/29/2005, you wrote: >Has anyone ever removed the four bolts that hold the exaust to the >unit? We need to replace the exaust but am afraid that removing them >could open us up for another big problem. The threaded pipe used is so >rusty it is not possible to take it apart in peices like it should be. >Might have to cut it near the cooler and try and unthread the peice >that goes in to the cooler? >Thankyou for any help! >Jeff & Michelle August >1980 FC35RB >Plymouth Wi Perkins Exaust Cooler - Shawn Fountain - 10-31-2005 06:59 Jeff, I also want new gen exhaust. Do you have phone #, part # and price? Are you looking for standard replacement or one specifically designed to be more quiet? Tks, SDF ----Original Message Follows---- From: "Jeff August" Reply-To: WanderlodgeForum@yahoogroups.com To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Perkins Exaust Cooler Date: Sat, 29 Oct 2005 14:22:34 -0000 Has anyone ever removed the four bolts that hold the exaust to the unit? We need to replace the exaust but am afraid that removing them could open us up for another big problem. The threaded pipe used is so rusty it is not possible to take it apart in peices like it should be. Might have to cut it near the cooler and try and unthread the peice that goes in to the cooler? Thankyou for any help! Jeff & Michelle August 1980 FC35RB Plymouth Wi |
