Safe-line - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Safe-line (/showthread.php?tid=1503) |
Safe-line - erniecarpet@... - 10-31-2005 03:26 Thanks, Curt, this was a first for me and have not remembered seeing this problem before. Ernie-83pt40- blinking lites in montana [Non-text portions of this message have been removed] Safe-line - Ernest Ekberg - 10-31-2005 05:33 took the coach out this am to top off fuel tank. Came back and plugged her back in. the engine is off, key off, but the safe-line lite is blinking. Anyone ever had this happen? Thank heavens, I can turn that buzzer off. Ernie-83pt40 in montana Safe-line - Curt Sprenger - 10-31-2005 05:51 Ernie, Our safe-line lite and buzzer will do the same thing, just not often. All I've done is to restart the engine and turn it off, problem goes away. Not a real fix. When I get some time I plan to check the lite/buzzer/switch and panel for ground problems. The panel is the overhead above the windshield. Other switches and gauges have issues as well. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Ernest Ekberg wrote: > took the coach out this am to top off fuel tank. Came back and plugged > her back in. the engine is off, key off, but the safe-line lite is > blinking. Anyone ever had this happen? Thank heavens, I can turn that > buzzer off. Ernie-83pt40 in montana > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > Safe-line - Richard Hayden - 10-31-2005 06:43 Curt and Ernie, Mine has been working intermittently recently. Sometimes not working when starting the engine and the ac plug still in. Not consistant though. This will be interesting and educational to follow. No time right now to delve into right now as we are leaving for AZ at weeks end. Richard Hayden '87 38 PT - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Monday, October 31, 2005 9:51 AM Subject: Re: [WanderlodgeForum] Safe-line Ernie, Our safe-line lite and buzzer will do the same thing, just not often. All I've done is to restart the engine and turn it off, problem goes away. Not a real fix. When I get some time I plan to check the lite/buzzer/switch and panel for ground problems. The panel is the overhead above the windshield. Other switches and gauges have issues as well. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Ernest Ekberg wrote: > took the coach out this am to top off fuel tank. Came back and plugged > her back in. the engine is off, key off, but the safe-line lite is > blinking. Anyone ever had this happen? Thank heavens, I can turn that > buzzer off. Ernie-83pt40 in montana > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum<http://groups.yahoo.com/group/Wa\ nderlodgeForum>>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/<http://docs.yahoo.com/info/terms/>>. > > > ------------------------------------------------------------------------ > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] Safe-line - Ralph L. Fullenwider - 10-31-2005 16:27 Ernie: The safe line lights and piazo buzzer are activated by a relay on top of your kitchen LP heater. The coil of that relay is pulled in by 110 vac from the shore power source, be it 50 AMP or 30 AMP that comes off the manual voltage transfer switch. The 12 VDC coming from the key switch, goes through the contacts on that relay to the lights. It sounds like the problem is between the key switch and the relay contacts. Ralph At 05:33 PM 10/31/2005 +0000, you wrote: >took the coach out this am to top off fuel tank. Came back and plugged >her back in. the engine is off, key off, but the safe-line lite is >blinking. Anyone ever had this happen? Thank heavens, I can turn that >buzzer off. Ernie-83pt40 in montana > > > > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm Safe-line - erniecarpet@... - 11-01-2005 11:36 Thanks, ralph, it took care of itself today- maybe too much dust in there from my dusty location? Ernie- in Douglas, Wyoming -----Original Message----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Mon, 31 Oct 2005 22:27:18 -0600 Subject: Re: [WanderlodgeForum] Safe-line Ernie: The safe line lights and piazo buzzer are activated by a relay on top of your kitchen LP heater. The coil of that relay is pulled in by 110 vac from the shore power source, be it 50 AMP or 30 AMP that comes off the manual voltage transfer switch. The 12 VDC coming from the key switch, goes through the contacts on that relay to the lights. It sounds like the problem is between the key switch and the relay contacts. Ralph At 05:33 PM 10/31/2005 +0000, you wrote: >took the coach out this am to top off fuel tank. Came back and plugged >her back in. the engine is off, key off, but the safe-line lite is >blinking. Anyone ever had this happen? Thank heavens, I can turn that >buzzer off. Ernie-83pt40 in montana > > > > > > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm Yahoo! Groups Links [Non-text portions of this message have been removed] |
