Interstate System Weight Limits - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Interstate System Weight Limits (/showthread.php?tid=1514) |
Interstate System Weight Limits - David Brady - 11-02-2005 01:52 Tom, From the Federal Highway Administration web site: http://vsw.fhwa.dot.gov/qa/qa.jsp?category=23%20CFR%20658.17 Correct me if I'm wrong, but I think the drive/tag axles on an LXi qualify as a Tandem axle. *May States set weight limits on the Interstate System at less than the Federal maximum weight limits?* "No. When Interstate System weight limits were raised to the current levels in 1974 (20,000 pounds single axle, 34,000 pounds tandem axle, 80,000 pounds overall gross weight limits, plus bridge formula limits), States were not required to raise their limits accordingly, although most did. However, six contiguous States in the Mississippi valley, referred to as the "barrier States," did not and effectively limited the weight for all vehicles moving across them to their own limits. This was changed in 1982 when Congress established Interstate System weight limits as minimums as well as maximums." *What is the definition of a tandem axle?* "It is two or more consecutive axles over 40 inches but not over 96 inches apart. If there were 3 axles within that distance, they would be considered a tandem axle for the purpose of Interstate weight limits." Best regards, David Brady '02 LXi, Smokey, Va Tom Warner wrote: >David you are already 2000# over the Federally mandated maximum for >your drive axel of 20,000 # per axel. Hope you are never stopped and >checked. That was one of the problems with the BB...to heavy! > >Tom Warner >1982 FC35 >Vernon Center,NY > > -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.362 / Virus Database: 267.12.7/155 - Release Date: 11/1/2005 Interstate System Weight Limits - David Brady - 11-02-2005 02:05 Oops, I think I see what you mean Tom. What the fhwa site is saying is that even in a Tandem configuration, no single axle can exceed 20000 lbs. Is this correct. If so, then you are right, and my LXi is overweight by federal standards. I hope I don't get stopped... David Brady '02 LXi, Smokey, Va David Brady wrote: >Tom, > > From the Federal Highway Administration web site: >http://vsw.fhwa.dot.gov/qa/qa.jsp?category=23%20CFR%20658.17 >Correct me if I'm wrong, but I think the drive/tag axles on an >LXi qualify as a Tandem axle. > >*May States set weight limits on the Interstate >System at less than the Federal maximum weight limits?* > >"No. When Interstate System weight limits were raised to the current >levels in >1974 (20,000 pounds single axle, 34,000 pounds tandem axle, 80,000 pounds >overall gross weight limits, plus bridge formula limits), States were >not required >to raise their limits accordingly, although most did. However, six >contiguous >States in the Mississippi valley, referred to as the "barrier States," >did not >and effectively limited the weight for all vehicles moving across them to >their own limits. This was changed in 1982 when Congress established >Interstate System weight limits as minimums as well as maximums." > >*What is the definition of a tandem axle?* > >"It is two or more consecutive axles over 40 inches but not over 96 inches >apart. If there were 3 axles within that distance, they would be considered >a tandem axle for the purpose of Interstate weight limits." > >Best regards, >David Brady >'02 LXi, Smokey, Va > >Tom Warner wrote: > > > >>David you are already 2000# over the Federally mandated maximum for >>your drive axel of 20,000 # per axel. Hope you are never stopped and >>checked. That was one of the problems with the BB...to heavy! >> >>Tom Warner >>1982 FC35 >>Vernon Center,NY >> >> >> >> > > > > > -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.362 / Virus Database: 267.12.7/155 - Release Date: 11/1/2005 Interstate System Weight Limits - Tom Warner - 11-02-2005 02:37 David I always thought that no single axel can exceed 20,000# period (as it states). And tandem axels cannot exceed 34000# . I interpret that to mean that the steer axel and tandem axel drive wheels cannot exceed 20,000# and the tags 14,000#. Tom Warner 1982 FC35 Vernon Center,NY At 08:52 AM 11/2/2005, you wrote: >Tom, > > From the Federal Highway Administration web site: ><http://vsw.fhwa.dot.gov/qa/qa.jsp?category=23%20CFR%20658.17>http://vsw.fhwa.d\ ot.gov/qa/qa.jsp?category=23%20CFR%20658.17 >Correct me if I'm wrong, but I think the drive/tag axles on an >LXi qualify as a Tandem axle. > >*May States set weight limits on the Interstate >System at less than the Federal maximum weight limits?* > >"No. When Interstate System weight limits were raised to the current >levels in >1974 (20,000 pounds single axle, 34,000 pounds tandem axle, 80,000 pounds >overall gross weight limits, plus bridge formula limits), States were >not required >to raise their limits accordingly, although most did. However, six >contiguous >States in the Mississippi valley, referred to as the "barrier States," >did not >and effectively limited the weight for all vehicles moving across them to >their own limits. This was changed in 1982 when Congress established >Interstate System weight limits as minimums as well as maximums." > >*What is the definition of a tandem axle?* > >"It is two or more consecutive axles over 40 inches but not over 96 inches >apart. If there were 3 axles within that distance, they would be considered >a tandem axle for the purpose of Interstate weight limits." > >Best regards, >David Brady >'02 LXi, Smokey, Va > >Tom Warner wrote: > > >David you are already 2000# over the Federally mandated maximum for > >your drive axel of 20,000 # per axel. Hope you are never stopped and > >checked. That was one of the problems with the BB...to heavy! > > > >Tom Warner > >1982 FC35 > >Vernon Center,NY > > > > > > > >-- >No virus found in this outgoing message. >Checked by AVG Free Edition. >Version: 7.1.362 / Virus Database: 267.12.7/155 - Release Date: 11/1/2005 > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Interstate System Weight Limits - g_man1146 - 11-02-2005 02:58 Hi All, Re axle weights; motorcoaches and RV's are exempt from the Commercial Truck 20K axle limit in most every (all?) states per legislation recently extended to 2009. This is due to the differences between truck "tandem" axles and buses with tag axles. RV's may be exempt on their own in some states or grouped with over the road busses in others. Either way, commercial truck regs do not apply per Fed DOT. The exemption, I'm told, once only applied to Transit (Municipally owned) busses and RV's but now includes commercial OTR buses. The Highway Bill (SAFETEA-LU) Axle Weight Exemptions Issue: Over-the-road buses (OTRBs), like traditional transit buses, have been carrying progressively more weight on each axle due to government mandates, the latest being the wheelchair lifts required by the Americans with Disabilities Act and market driven amenities. As a consequence, fully loaded OTRBs approach, and sometimes may exceed, the federal axle weight restrictions of 34,000 lbs. on the tandem axle (with no single axle allowed to carry more than 20,000 lbs.). For example a tandem could be 17,000-17,000, but cannot be 21,000-16,000. Motorcoaches and trucks should not have the same axle weight limits due to the fundamental differences in vehicle design, configuration, and vehicle use. A separate weight limit should be developed for motorcoaches and other passenger carrying vehicles. What's In It For You? : The current legislation allows the states to exempt motorcoaches from axle weight restrictions on the interstates. Fines are dependent on a number of factors, including how much overweight they are, etc. and could be in the hundreds of dollars. When Does This Start: Congress granted a temporary axle weight exemption for buses. This is a continuation of language that we obtained previously, and will continue through 2009. What's Next: The majority of states are already exempt. Please notify ABA if you encounter sates that do not exempt motorcoaches. NOTE: For information on "off-interstate" do a google search for (22,500 axle weight) find any state you wish and check the regulations. As always, states (or towns) may limit weight on a particulay road just as they limit certain roads for passenger cars only. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > Tom, > > From the Federal Highway Administration web site: > http://vsw.fhwa.dot.gov/qa/qa.jsp?category=23%20CFR%20658.17 > Correct me if I'm wrong, but I think the drive/tag axles on an > LXi qualify as a Tandem axle. > > *May States set weight limits on the Interstate > System at less than the Federal maximum weight limits?* > > "No. When Interstate System weight limits were raised to the current > levels in > 1974 (20,000 pounds single axle, 34,000 pounds tandem axle, 80,000 pounds > overall gross weight limits, plus bridge formula limits), States were > not required > to raise their limits accordingly, although most did. However, six > contiguous > States in the Mississippi valley, referred to as the "barrier States," > did not > and effectively limited the weight for all vehicles moving across them to > their own limits. This was changed in 1982 when Congress established > Interstate System weight limits as minimums as well as maximums." > > *What is the definition of a tandem axle?* > > "It is two or more consecutive axles over 40 inches but not over 96 inches > apart. If there were 3 axles within that distance, they would be considered > a tandem axle for the purpose of Interstate weight limits." > > Best regards, > David Brady > '02 LXi, Smokey, Va > > Tom Warner wrote: > > >David you are already 2000# over the Federally mandated maximum for > >your drive axel of 20,000 # per axel. Hope you are never stopped and > >checked. That was one of the problems with the BB...to heavy! > > > >Tom Warner > >1982 FC35 > >Vernon Center,NY > > > > > > > > -- > No virus found in this outgoing message. > Checked by AVG Free Edition. > Version: 7.1.362 / Virus Database: 267.12.7/155 - Release Date: 11/1/2005 > |
