batteries - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: batteries (/showthread.php?tid=1516) |
batteries - dspithaler@... - 11-02-2005 02:37 Rich When I got my 89 SP 36' it had 4-12 Volt Deep cycle Interstate for the house in the front compartment & 2- 12 Volt Deep cycle in the rear for the Cat starting batteries. The house batteries had 2 that were weak so I changed the 4 to 4-- 6 Volt Trojan batteries & left the 12 Volt deep cycle in the rear as they were good. Was that a bad idea??? Now two years later I am going to change the Starting batteries to 2--12 volt Interstate starting batteries as I thought they are better for starting than the Deep Cycle. Is that going to work & be good? Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] batteries - ingamar2 - 11-02-2005 05:01 I have owned a 90WBWL for three years and have had troubles starting it in cold weather(25 to 30 degrees). The starting batteries and the house batteries are the same. There are six total and are now about four years old. I would guess they are ready to be changed out but was wondering if someone out there has changed the way they are setup. Can you put four house batteries and two starting batteries in a sereis or do they all have to be the same as it is now. Can you seperate the house batteries from the starting batteries as it is in most coachs. Can anyone recommend a certain battery that is better than others. Craig Hovda 90WBWL Bigfork Mt. batteries - g_man1146 - 11-02-2005 05:29 Hi Craig, If all the batteries are connected in parallel, such as I had on my '90, do not mix types. They should all be deep cycle batteries which, in good condition, will crank just fine. Sounds like your batteries are about gone. I used Interstate 12 vdc, deep cycle, lead acid batteries with excellent results. Another option, if they fit is to use 6, 6 volt golf cart batteries wired in series/parallel to give you 12 volts. (Each pair of 6 volt are wired in series to give you 12 V, then the three pairs are wired in parallel to maintain the 12 V.) Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "ingamar2" > > I have owned a 90WBWL for three years and have had troubles starting > it in cold weather(25 to 30 degrees). The starting batteries and the > house batteries are the same. There are six total and are now about > four years old. I would guess they are ready to be changed out but was > wondering if someone out there has changed the way they are setup. Can > you put four house batteries and two starting batteries in a sereis or > do they all have to be the same as it is now. Can you seperate the > house batteries from the starting batteries as it is in most coachs. > Can anyone recommend a certain battery that is better than others. > > Craig Hovda > 90WBWL > Bigfork Mt. > batteries - dspithaler@... - 11-02-2005 06:30 Thanks Rich That's what I thought you meant when you said not mix batteries I wanted to make sure that I hadn't done something wrong Don 89 SP 36' Butler, PA Mixing battery types in the same bank (connected together) is not a good idea. Having two different types in different banks, such as you have (or are going to do), is not a problem as long as they require the same charging voltage. The four 6 volt lead-acid batteries connected in series/parallel will charge with the same voltage as the two 12 volt lead-acid in parallel. Gel batteries and, to a lesser extent, AGM's should never be charged with the same voltage as lead-acid batteries. Doing so will damage the Gel/AGM's as they require lower charging voltages. Yes, if the batteries are for starting only, go to the Interstate starting batteries in the rear. Deep cycle batteries can be used for starting but not vice versa as starting batteries will suffer if used for the deep discharge "house" use. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > Rich When I got my 89 SP 36' it had 4-12 Volt Deep cycle Interstate for > the house in the front compartment & 2- 12 Volt Deep cycle in the rear for > the Cat starting batteries. The house batteries had 2 that were weak so I > changed the 4 to 4-- 6 Volt Trojan batteries & left the 12 Volt deep cycle in the > rear as they were good. Was that a bad idea??? Now two years later I am > going to change the Starting batteries to 2--12 volt Interstate starting > batteries as I thought they are better for starting than the Deep Cycle. Is that > going to work & be good? > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] batteries - dspithaler@... - 11-02-2005 06:53 Hank I have had 4 6 Volt Trojans in my 79FC 33' for six years & they are doing fine yet. They are house & starting in one bank. They are the small ones. I don't remember the size of them The genny has a 12 Volt for it. I have had 4 6 Volt Trojans in the 89 SP as house batteries for 2 years & they are doing fine. They are 145's & just fit in the compartment for height. They were also $397.50 for the 4. They are a lot heaver also. Probably have me over the weight limit????? Don 89 SP 36' Butler, PA ---DON: RE: Batterys...I have two 12v INTERSTATE batterys in my 90SP36..been working fine for 2 yrs.....also have four 12v house batteries in front for house...got them from wal-mart two yrs ago..still running.......I have 6v trojans in my MH in Australia and like them after 5 years still working but they are recharged bu SLOAR all the time..........would like to hear from u about trojans working in you SP36 hjouse. Regards, Hank Hannigan 90SP36 [Non-text portions of this message have been removed] batteries - erniecarpet@... - 11-02-2005 06:58 Craig, when it gets below 50 I turn on my block heater. Maybe the fella that has the coach where you park it can turn on the heater before you try and start it. Don't want you to miss any MSU games! Ernie 83pt40 in Kansas [Non-text portions of this message have been removed] batteries - dspithaler@... - 11-02-2005 07:13 Thanks Blair & Rich for the battery info. Don 89 SP 36' Butler, PA At 11:37 AM 11/2/2005, you wrote: >Rich When I got my 89 SP 36' it had 4-12 Volt Deep cycle Interstate for >the house in the front compartment & 2- 12 Volt Deep cycle in the rear for >the Cat starting batteries. The house batteries had 2 that were weak so I >changed the 4 to 4-- 6 Volt Trojan batteries & left the 12 Volt deep >cycle in the >rear as they were good. Was that a bad idea??? Now two years later I am >going to change the Starting batteries to 2--12 volt Interstate starting >batteries as I thought they are better for starting than the Deep Cycle. >Is that >going to work & be good? > Don > 89 SP 36' > Butler, PA Deep cycle batteries are made totally different from starting batteries. They can be discharged to 50% for 1000-2000 cycles before dying, sometimes more. However, they are NOT made to be used for a high amperage discharge rate as when in starting your engine. It will kill them very quick. 50% discharge is about 12 volts. It you set it up so the lowest voltage is higher than 12 volts, the life of the batteries is greatly increased If you take a starting battery, brand new in your car, and let it run down overnight and then recharge, and do it night after night, it might last, if lucky, ten days. They are not made for multiple cycles of deep discharge. They are designed for short, high amperage discharge as in starting your engine. The best mix is to have a separate starting battery and another set of deep cycle glass or AGM's for the coach. If you use AGM's, you can use the same bulk and float settings as on the starting lead acid battery, making it real simple to set up. Not so with glass mat. I installed 3 8D AGM's for the coach and 1 8D lead acid for the chassis. The bulk charge is 14.4 volts and the float charge is 14.0 and it echo charges the chassis battery to 13.5volts. This give me over 800 amp hours at 12 volts for dry camping. When the voltage reaches 12, it signals the genset to start, makes it real simple... Blair in Oregon [Non-text portions of this message have been removed] batteries - Henry Jay Hannigan - 11-02-2005 08:21 ---DON: RE: Batterys...I have two 12v INTERSTATE batterys in my 90SP36..been working fine for 2 yrs.....also have four 12v house batteries in front for house...got them from wal-mart two yrs ago..still running.......I have 6v trojans in my MH in Australia and like them after 5 years still working but they are recharged bu SLOAR all the time..........would like to hear from u about trojans working in you SP36 hjouse. Regards, Hank Hannigan 90SP36 In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > Rich When I got my 89 SP 36' it had 4-12 Volt Deep cycle Interstate for > the house in the front compartment & 2- 12 Volt Deep cycle in the rear for > the Cat starting batteries. The house batteries had 2 that were weak so I > changed the 4 to 4-- 6 Volt Trojan batteries & left the 12 Volt deep cycle in the > rear as they were good. Was that a bad idea??? Now two years later I am > going to change the Starting batteries to 2--12 volt Interstate starting > batteries as I thought they are better for starting than the Deep Cycle. Is that > going to work & be good? > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] > batteries - g_man1146 - 11-02-2005 09:18 Don, Mixing battery types in the same bank (connected together) is not a good idea. Having two different types in different banks, such as you have (or are going to do), is not a problem as long as they require the same charging voltage. The four 6 volt lead-acid batteries connected in series/parallel will charge with the same voltage as the two 12 volt lead-acid in parallel. Gel batteries and, to a lesser extent, AGM's should never be charged with the same voltage as lead-acid batteries. Doing so will damage the Gel/AGM's as they require lower charging voltages. Yes, if the batteries are for starting only, go to the Interstate starting batteries in the rear. Deep cycle batteries can be used for starting but not vice versa as starting batteries will suffer if used for the deep discharge "house" use. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > Rich When I got my 89 SP 36' it had 4-12 Volt Deep cycle Interstate for > the house in the front compartment & 2- 12 Volt Deep cycle in the rear for > the Cat starting batteries. The house batteries had 2 that were weak so I > changed the 4 to 4-- 6 Volt Trojan batteries & left the 12 Volt deep cycle in the > rear as they were good. Was that a bad idea??? Now two years later I am > going to change the Starting batteries to 2--12 volt Interstate starting > batteries as I thought they are better for starting than the Deep Cycle. Is that > going to work & be good? > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] > batteries - Blair - 11-02-2005 09:50 At 11:37 AM 11/2/2005, you wrote: >Rich When I got my 89 SP 36' it had 4-12 Volt Deep cycle Interstate for >the house in the front compartment & 2- 12 Volt Deep cycle in the rear for >the Cat starting batteries. The house batteries had 2 that were weak so I >changed the 4 to 4-- 6 Volt Trojan batteries & left the 12 Volt deep >cycle in the >rear as they were good. Was that a bad idea??? Now two years later I am >going to change the Starting batteries to 2--12 volt Interstate starting >batteries as I thought they are better for starting than the Deep Cycle. >Is that >going to work & be good? > Don > 89 SP 36' > Butler, PA Deep cycle batteries are made totally different from starting batteries. They can be discharged to 50% for 1000-2000 cycles before dying, sometimes more. However, they are NOT made to be used for a high amperage discharge rate as when in starting your engine. It will kill them very quick. 50% discharge is about 12 volts. It you set it up so the lowest voltage is higher than 12 volts, the life of the batteries is greatly increased If you take a starting battery, brand new in your car, and let it run down overnight and then recharge, and do it night after night, it might last, if lucky, ten days. They are not made for multiple cycles of deep discharge. They are designed for short, high amperage discharge as in starting your engine. The best mix is to have a separate starting battery and another set of deep cycle glass or AGM's for the coach. If you use AGM's, you can use the same bulk and float settings as on the starting lead acid battery, making it real simple to set up. Not so with glass mat. I installed 3 8D AGM's for the coach and 1 8D lead acid for the chassis. The bulk charge is 14.4 volts and the float charge is 14.0 and it echo charges the chassis battery to 13.5volts. This give me over 800 amp hours at 12 volts for dry camping. When the voltage reaches 12, it signals the genset to start, makes it real simple... Blair in Oregon [Non-text portions of this message have been removed] |
