stuck at RATS - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: stuck at RATS (/showthread.php?tid=1526) |
stuck at RATS - fl_bluebird_1983 - 11-05-2005 05:50 Crit Bliss (1980 FC) is having a problem starting his coach, he thought it was a fuel solenoid, he replaced that and still has same problem. Now when he turns on the ignition the third breaker from the top in the center row of breakers trips, we took the wires loose and there is a red and black wire in the same crimp connector that is causing the breaker to trip. It reads 0 ohms to ground, we think it goes to the fuel soleniod. My question, is there a fuel solenoid RELAY and if so WHERE. The starter still seem to be getting power, but no fuel to start. If you can help him PLEASE call him at 508-237-0091, or if you can't call a post with ANY info would be helpful. Thanks Bruce Campbell "Blue Skies" |
