Coolant PH - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Coolant PH (/showthread.php?tid=1532) |
Coolant PH - Larry holland - 11-06-2005 13:06 Does anyone know what the PH level should be for the engine coolant in the 3208 Cat? Mine is testing at an 11 PH, making it very alkiline. I purchased an SCA additive from Caterpiller and after reading the label found that it is an alkiline base. Using it will only raise my PH. The people at the local Cat distributor didn't have a clue about the PH. My coolant protection is testing down to minus 34 deg. It is still bright green but getting old. What should I expect its useful life to be? Thanks, Larry Holland /82FC35SB Canandaigua, N.Y. [Non-text portions of this message have been removed] Coolant PH - Tom Warner - 11-06-2005 13:12 Larry go to NAPA and get Pennray coolant test strips to test your coolant. They arent expensive and the directions are on the label. The color is not important if it tests alright. Tom Warner 1982 Bluebird Vernon Center,NY At 08:06 PM 11/6/2005, you wrote: >Does anyone know what the PH level should be for the engine coolant >in the 3208 Cat? Mine is testing at an 11 PH, making it very >alkiline. I purchased an SCA additive from Caterpiller and after >reading the label found that it is an alkiline base. Using it will >only raise my PH. The people at the local Cat distributor didn't >have a clue about the PH. My coolant protection is testing down to >minus 34 deg. It is still bright green but getting old. What should >I expect its useful life to be? > >Thanks, > >Larry Holland /82FC35SB > >Canandaigua, N.Y. > > > >[Non-text portions of this message have been removed] > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehi\ cles&w2=Automotive+maintenance&c=2&s=55&.sig=F0lIKEg_mI9Zn2uI3r-I5w>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+veh\ icles&w2=Automotive+maintenance&c=2&s=55&.sig=Q8l-p3rdqKksggFZAmUZNg>Automotive >maintenance > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Coolant PH - Bruce Morris - 11-06-2005 13:33 The coolant ph should run between 9.8 and 10.5, but check out the link I've included. It has some good information regarding this matter. http://www.tandmautomotive.com/1/info/cooling_system.html Bruce Morris (919)872-7635 Raleigh, NC Webmaster - Wanderlodge Owners Online http://www.wanderlodge.us 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: Larry holland To: WanderlodgeForum@yahoogroups.com Sent: Sunday, November 06, 2005 8:06 PM Subject: [WanderlodgeForum] Coolant PH Does anyone know what the PH level should be for the engine coolant in the 3208 Cat? Mine is testing at an 11 PH, making it very alkiline. I purchased an SCA additive from Caterpiller and after reading the label found that it is an alkiline base. Using it will only raise my PH. The people at the local Cat distributor didn't have a clue about the PH. My coolant protection is testing down to minus 34 deg. It is still bright green but getting old. What should I expect its useful life to be? Thanks, Larry Holland /82FC35SB Canandaigua, N.Y. [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Automotive maintenance ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
