Electrical loss - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Electrical loss (/showthread.php?tid=1570) |
Electrical loss - g - 11-19-2005 04:21 I have a problem that I have not encountered before. Went to move thge coach yesterday and batteries were dead, I left the disconnect closed. So charged batts and tried to start, nothing. No power to dash, switch etc. Just like the main disconnect was off. Had power to the electronics. Went out this am and same thing, But after several tries everything on the dash comes on and coach fires right up like always, air came up and genset tray moved right in when I hit the switch(another first by the way). I stepped inside and heard the coach quit. Went back out and was like I had turned off main disconnect under the dash, just like yesterday. any one know where to start looking. I hate intermittent problems Glenn Shehorn 83FC35 Kansas City Mo [Non-text portions of this message have been removed] Electrical loss - pattypape - 11-19-2005 04:33 Glenn, If the batteries are good,??, I would first clean the battery posts, and check the ground connections. Then check up on the ignition switch, carry a spare, ( inexpensive part to carry ) , On our 88 there are four or five big cable connectors under the dash, These are sometimes not very reliable and become intermittent. Everything on the dash and ignition switch runs through these connectors. Loosen these connectors blow the dirt out, lubricate with electronic spray cleaner, be sure to retighten them. Bill 88 FC michigan --- In WanderlodgeForum@yahoogroups.com, "g" > > I have a problem that I have not encountered before. Went to move thge coach yesterday and batteries were dead, I left the disconnect closed. So charged batts and tried to start, nothing. No power to dash, switch etc. Just like the main disconnect was off. Had power to the electronics. Went out this am and same thing, But after several tries everything on the dash comes on and coach fires right up like always, air came up and genset tray moved right in when I hit the switch(another first by the way). I stepped inside and heard the coach quit. Went back out and was like I had turned off main disconnect under the dash, just like yesterday. > any one know where to start looking. > I hate intermittent problems > > Glenn Shehorn > 83FC35 > Kansas City Mo > > [Non-text portions of this message have been removed] > |
