FC31 questions - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FC31 questions (/showthread.php?tid=1602) |
FC31 questions - Craig Schwartz - 11-24-2005 08:02 Hi, I'm considering buying a 1974 FC31, and have a few questions that someone might be able to answer for me: a) the tank monitor display, mounted on the kitchenette wall, does not show any indicator lights (on) giving the status of the various tanks (water, grey, black). The "pump on" led is lit, and the water pump on/off switch works. Water comes out of the faucet when "on", and not when "off". Is this a problem ? is there a switch somewhere else that needs to be thrown to enable the tank usage readout ? Or is it perhaps that there is so little water that, although it came out of the faucett, that not enough is in any tank to register ? How might I diagnose this ? b) what are the various tank capacities ? c) Is it feasible to add additional propane storage , given the amount of room avaialble underneath, and safety considerations ? d) does anyone know the current loads of any of the various coach electronics (a/c , refrigerator, exhaust fan, microwave ? I'd like to see if I can reduce use of the generator by storing power in batteries, and need to estimate my system power needs. thanks, Craig FC31 questions - Curt Sprenger - 11-24-2005 08:42 Graig, I'll try to help. Where are you located? To comply with the forum rules you should provide that information. Thanks. Tank monitor...each tank needs to be at least 1/4 full for the monitor panel test or show other than empty. Tanks capacities...fresh water 60/65 gal., waste and gray 40 gal. each. Water pump switch...must be on for water to come out of the faucets. Switch Off and no water out of the faucets is not a problem. Adding propane is feasible. Most generators die from lack of maintenance and the lack of frequent use. Elec. loads...I can't help you with that one. Hope this helps some. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Craig Schwartz wrote: > Hi, > I'm considering buying a 1974 FC31, and have a few questions > that someone might be able to answer for me: > > a) the tank monitor display, mounted on the kitchenette wall, > does not show any indicator lights (on) giving the status of > the various tanks (water, grey, black). The "pump on" led is lit, > and the water pump on/off switch works. Water comes out of the faucet > when "on", and not when "off". Is this a problem ? is there > a switch somewhere else that needs to be thrown to enable the > tank usage readout ? Or is it perhaps that there is so little > water that, although it came out of the faucett, that not enough > is in any tank to register ? How might I diagnose this ? > > b) what are the various tank capacities ? > > c) Is it feasible to add additional propane storage , given > the amount of room avaialble underneath, and safety considerations ? > > d) does anyone know the current loads of any of the various coach > electronics (a/c , refrigerator, exhaust fan, microwave ? I'd > like to see if I can reduce use of the generator by storing power > in batteries, and need to estimate my system power needs. > > thanks, > Craig > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > FC31 questions - Craig Schwartz - 11-24-2005 12:32 Hi Curt, sorry about the omission: I'm in the Los Angeles area. - Craig --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Graig, > I'll try to help. > > Where are you located? To comply with the forum rules you should provide > that information. Thanks. > > Tank monitor...each tank needs to be at least 1/4 full for the monitor > panel test or show other than empty. > > Tanks capacities...fresh water 60/65 gal., waste and gray 40 gal. each. > > Water pump switch...must be on for water to come out of the faucets. > Switch Off and no water out of the faucets is not a problem. > > Adding propane is feasible. Most generators die from lack of maintenance > and the lack of frequent use. > > Elec. loads...I can't help you with that one. > > Hope this helps some. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Craig Schwartz wrote: > > > Hi, > > I'm considering buying a 1974 FC31, and have a few questions > > that someone might be able to answer for me: > > > > a) the tank monitor display, mounted on the kitchenette wall, > > does not show any indicator lights (on) giving the status of > > the various tanks (water, grey, black). The "pump on" led is lit, > > and the water pump on/off switch works. Water comes out of the faucet > > when "on", and not when "off". Is this a problem ? is there > > a switch somewhere else that needs to be thrown to enable the > > tank usage readout ? Or is it perhaps that there is so little > > water that, although it came out of the faucett, that not enough > > is in any tank to register ? How might I diagnose this ? > > > > b) what are the various tank capacities ? > > > > c) Is it feasible to add additional propane storage , given > > the amount of room avaialble underneath, and safety considerations ? > > > > d) does anyone know the current loads of any of the various coach > > electronics (a/c , refrigerator, exhaust fan, microwave ? I'd > > like to see if I can reduce use of the generator by storing power > > in batteries, and need to estimate my system power needs. > > > > thanks, > > Craig > > > > > > > > > > ----------------------------------------------------------------- ------- > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ----------------------------------------------------------------- ------- > > > FC31 questions - Curt Sprenger - 11-24-2005 17:09 Craig, No problem. Can I ask about the coach you are looking at? I sold a 1974 FC31 and I believe the gal that bought it from me has it for sale. I can help you with a lot of information if it is the coach I sold. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Craig Schwartz wrote: > Hi Curt, > sorry about the omission: I'm in the Los Angeles area. > - Craig > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > Graig, > > I'll try to help. > > > > Where are you located? To comply with the forum rules you should > provide > > that information. Thanks. > > > > Tank monitor...each tank needs to be at least 1/4 full for the > monitor > > panel test or show other than empty. > > > > Tanks capacities...fresh water 60/65 gal., waste and gray 40 gal. > each. > > > > Water pump switch...must be on for water to come out of the > faucets. > > Switch Off and no water out of the faucets is not a problem. > > > > Adding propane is feasible. Most generators die from lack of > maintenance > > and the lack of frequent use. > > > > Elec. loads...I can't help you with that one. > > > > Hope this helps some. > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > Craig Schwartz wrote: > > > > > Hi, > > > I'm considering buying a 1974 FC31, and have a few questions > > > that someone might be able to answer for me: > > > > > > a) the tank monitor display, mounted on the kitchenette wall, > > > does not show any indicator lights (on) giving the status of > > > the various tanks (water, grey, black). The "pump on" led is lit, > > > and the water pump on/off switch works. Water comes out of the > faucet > > > when "on", and not when "off". Is this a problem ? is there > > > a switch somewhere else that needs to be thrown to enable the > > > tank usage readout ? Or is it perhaps that there is so little > > > water that, although it came out of the faucett, that not enough > > > is in any tank to register ? How might I diagnose this ? > > > > > > b) what are the various tank capacities ? > > > > > > c) Is it feasible to add additional propane storage , given > > > the amount of room avaialble underneath, and safety > considerations ? > > > > > > d) does anyone know the current loads of any of the various coach > > > electronics (a/c , refrigerator, exhaust fan, microwave ? I'd > > > like to see if I can reduce use of the generator by storing power > > > in batteries, and need to estimate my system power needs. > > > > > > thanks, > > > Craig > > > > > > > > > > > > > > > ----------------------------------------------------------------- > ------- > > > YAHOO! GROUPS LINKS > > > > > > * Visit your group "WanderlodgeForum > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the > web. > > > > > > * To unsubscribe from this group, send an email to: > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms > of > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > ----------------------------------------------------------------- > ------- > > > > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > FC31 questions - Curt Sprenger - 11-25-2005 11:35 Craig, I just happened to come across Coach Electronic Loads. The information is from our Bird Gen. Book. All values are Watts: Elec. Blanket 50 - 250, Blender 600, Hair Dryer, 500-1200, air circulating fan 25-100, Furnace fan, 270, Space heater 150-1500, Water heater 1500, Frying pan 1200, Coffee maker 650, Radio 50-100, TV 300-750, Toaster 750-1200. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Curt Sprenger wrote: > Craig, > No problem. > > Can I ask about the coach you are looking at? I sold a 1974 FC31 and I > believe the gal that bought it from me has it for sale. I can help you > with a lot of information if it is the coach I sold. > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Craig Schwartz wrote: > > > Hi Curt, > > sorry about the omission: I'm in the Los Angeles area. > > - Craig > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > > Graig, > > > I'll try to help. > > > > > > Where are you located? To comply with the forum rules you should > > provide > > > that information. Thanks. > > > > > > Tank monitor...each tank needs to be at least 1/4 full for the > > monitor > > > panel test or show other than empty. > > > > > > Tanks capacities...fresh water 60/65 gal., waste and gray 40 gal. > > each. > > > > > > Water pump switch...must be on for water to come out of the > > faucets. > > > Switch Off and no water out of the faucets is not a problem. > > > > > > Adding propane is feasible. Most generators die from lack of > > maintenance > > > and the lack of frequent use. > > > > > > Elec. loads...I can't help you with that one. > > > > > > Hope this helps some. > > > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > Craig Schwartz wrote: > > > > > > > Hi, > > > > I'm considering buying a 1974 FC31, and have a few questions > > > > that someone might be able to answer for me: > > > > > > > > a) the tank monitor display, mounted on the kitchenette wall, > > > > does not show any indicator lights (on) giving the status of > > > > the various tanks (water, grey, black). The "pump on" led is lit, > > > > and the water pump on/off switch works. Water comes out of the > > faucet > > > > when "on", and not when "off". Is this a problem ? is there > > > > a switch somewhere else that needs to be thrown to enable the > > > > tank usage readout ? Or is it perhaps that there is so little > > > > water that, although it came out of the faucett, that not enough > > > > is in any tank to register ? How might I diagnose this ? > > > > > > > > b) what are the various tank capacities ? > > > > > > > > c) Is it feasible to add additional propane storage , given > > > > the amount of room avaialble underneath, and safety > > considerations ? > > > > > > > > d) does anyone know the current loads of any of the various coach > > > > electronics (a/c , refrigerator, exhaust fan, microwave ? I'd > > > > like to see if I can reduce use of the generator by storing power > > > > in batteries, and need to estimate my system power needs. > > > > > > > > thanks, > > > > Craig > > > > > > > > > > > > > > > > > > > > ----------------------------------------------------------------- > > ------- > > > > YAHOO! GROUPS LINKS > > > > > > > > * Visit your group "WanderlodgeForum > > > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the > > web. > > > > > > > > * To unsubscribe from this group, send an email to: > > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms > > of > > > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > > > > > > > ----------------------------------------------------------------- > > ------- > > > > > > > > > > > > > > > > > > > > > SPONSORED LINKS > > Recreational vehicles > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw>> > > > Wanderlodge > > > <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ > <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>> > > > Automotive maintenance > > > <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA > <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA>> > > > > > Recreational vehicle dealer > > > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A>> > > > Used recreational vehicles > > > <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw > <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw>> > > > Automotive radiators > > > <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA > <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA>> > > > > > > > > > ------------------------------------------------------------------------ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ------------------------------------------------------------------------ > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
