Winter travel....(attn: Tom S.)... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Winter travel....(attn: Tom S.)... (/showthread.php?tid=1609) |
Winter travel....(attn: Tom S.)... - fwernlein - 11-25-2005 08:35 I thought it might be worthwile to start a new thread on this topic of winter travel. I would like to hear other opinions/experiences and any cautions. I have had my bus through 2 winters, and use it for skiing trips and other winter travel in VA/PA/NY. Some hook-up camping, most dry- camping. Most of my experience is in the low teens as far as low temps. Over the road: I have not had any big scares in snow/ice, I keep it slow and reasonable(not hard in an FC). The bus can skid, and inspite of the big weight, momentum on ice can surprise you. The bus stays toasty with the chassis heat. We feel very safe and comfy. Camping: I have two modes (wet water lines OR dry) 1: WET: I keep the fresh water tank filled as I expect to need it and I use on board water. Basically, this is normal camping 2: DRY: I use bottled water for sink and toilet flushing, thus only have to mess with draining the waste tanks. I do not "dewinterize" the water supply system. No showers...but you can maintain clean hands and face. For either: I keep either rock salt or pink anti-freeze in the waste tanks. I run the generator typically for breakfast and dinner (microwave and top off the batts), perhaps 30-45 mins both cycles-and always run long enought to full operating temp. At night, I run the propane heaters, usually deciding to use one or two based on the temp. forcast. Never needed all three going. My goal is to keep both the family AND the bus body interior warm (to prevent interior line freezing). I keep the access door in the bath vanity open at night. I have run two of the propane heaters with just batts overnight w/o problems (I have 6 6vt. golf batts). I do have an aux. CO detector that I installed. Main engine...I use the water block heater, and have battery blanket heaters. Never had a cold start issue with the 3208. Typically, I start the main at the end of my AM generator run... I think my biggest exposure to potential freezing problems is being out of the bus for a extended time w/o electric hookup. If parked and unattended/unheated...say for over 6+ hours, I would think the interior temps would drop enough for line freezing if they were "wet". This I try to avoid during below freezing weather. Frank 85FC33 Woodbridge, VA. Winter travel....(attn: Tom S.)... - thomas_sorrentino - 11-25-2005 12:24 Frank, Thanks thats exactly what I was looking for. One question. How do you get rock salt into the grey tank, and how much do you put in. Tom Sorrentino Bedford Hills, NY 1978 fc 33' --- In WanderlodgeForum@yahoogroups.com, "fwernlein" > > I thought it might be worthwile to start a new thread on this topic of > winter travel. I would like to hear other opinions/experiences and > any cautions. > > I have had my bus through 2 winters, and use it for skiing trips and > other winter travel in VA/PA/NY. Some hook-up camping, most dry- > camping. Most of my experience is in the low teens as far as low > temps. > > Over the road: I have not had any big scares in snow/ice, I keep it > slow and reasonable(not hard in an FC). The bus can skid, and inspite > of the big weight, momentum on ice can surprise you. The bus stays > toasty with the chassis heat. We feel very safe and comfy. > > Camping: I have two modes (wet water lines OR dry) 1: WET: I keep the > fresh water tank filled as I expect to need it and I use on board > water. Basically, this is normal camping 2: DRY: I use bottled > water for sink and toilet flushing, thus only have to mess with > draining the waste tanks. I do not "dewinterize" the water supply > system. No showers...but you can maintain clean hands and face. For > either: I keep either rock salt or pink anti-freeze in the waste tanks. > > I run the generator typically for breakfast and dinner (microwave and > top off the batts), perhaps 30-45 mins both cycles-and always run long > enought to full operating temp. At night, I run the propane heaters, > usually deciding to use one or two based on the temp. forcast. Never > needed all three going. My goal is to keep both the family AND the > bus body interior warm (to prevent interior line freezing). I keep > the access door in the bath vanity open at night. I have run two of > the propane heaters with just batts overnight w/o problems (I have 6 > 6vt. golf batts). I do have an aux. CO detector that I installed. > > Main engine...I use the water block heater, and have battery blanket > heaters. Never had a cold start issue with the 3208. Typically, I > start the main at the end of my AM generator run... > > I think my biggest exposure to potential freezing problems is being > out of the bus for a extended time w/o electric hookup. If parked and > unattended/unheated...say for over 6+ hours, I would think the > interior temps would drop enough for line freezing if they > were "wet". This I try to avoid during below freezing weather. > > Frank > 85FC33 > Woodbridge, VA. > Winter travel....(attn: Tom S.)... - ronmarabito2002 - 11-25-2005 13:07 That's a good explanation of your technique. I'm sure many will gleen good information from it. I rarely venture into snow and ice and prefer to remain away. I rarely have to winterize my coach since I am in Dallas. I do treat drains when temp gets into the 20's. I keep heat in the coach all winter so no problem with freezing lines. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "fwernlein" > > I thought it might be worthwile to start a new thread on this topic of > winter travel. I would like to hear other opinions/experiences and > any cautions. > > I have had my bus through 2 winters, and use it for skiing trips and > other winter travel in VA/PA/NY. Some hook-up camping, most dry- > camping. Most of my experience is in the low teens as far as low > temps. > > Over the road: I have not had any big scares in snow/ice, I keep it > slow and reasonable(not hard in an FC). The bus can skid, and inspite > of the big weight, momentum on ice can surprise you. The bus stays > toasty with the chassis heat. We feel very safe and comfy. > > Camping: I have two modes (wet water lines OR dry) 1: WET: I keep the > fresh water tank filled as I expect to need it and I use on board > water. Basically, this is normal camping 2: DRY: I use bottled > water for sink and toilet flushing, thus only have to mess with > draining the waste tanks. I do not "dewinterize" the water supply > system. No showers...but you can maintain clean hands and face. For > either: I keep either rock salt or pink anti-freeze in the waste tanks. > > I run the generator typically for breakfast and dinner (microwave and > top off the batts), perhaps 30-45 mins both cycles-and always run long > enought to full operating temp. At night, I run the propane heaters, > usually deciding to use one or two based on the temp. forcast. Never > needed all three going. My goal is to keep both the family AND the > bus body interior warm (to prevent interior line freezing). I keep > the access door in the bath vanity open at night. I have run two of > the propane heaters with just batts overnight w/o problems (I have 6 > 6vt. golf batts). I do have an aux. CO detector that I installed. > > Main engine...I use the water block heater, and have battery blanket > heaters. Never had a cold start issue with the 3208. Typically, I > start the main at the end of my AM generator run... > > I think my biggest exposure to potential freezing problems is being > out of the bus for a extended time w/o electric hookup. If parked and > unattended/unheated...say for over 6+ hours, I would think the > interior temps would drop enough for line freezing if they > were "wet". This I try to avoid during below freezing weather. > > Frank > 85FC33 > Woodbridge, VA. > Winter travel....(attn: Tom S.)... - fwernlein - 11-25-2005 14:28 Last year I put about 4 heaping cups rock salt into a bucket of warm water, then when "melted", poured into grey tank via the kitchen sink, I guess you could disolve it in the sink if you wanted. This year, I bought more gallons of the red RV anti-freeze, and plan to use it in lieu of salt...its easier, less "work" and I think gives more freeze protection per unit volume. Frank W. 85FC33 Woodbridge, VA. --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > Frank, > > Thanks thats exactly what I was looking for. One question. How do > you get rock salt into the grey tank, and how much do you put in. > > Tom Sorrentino > Bedford Hills, NY > 1978 fc 33' > Winter travel....(attn: Tom S.)... - ED GARDELS - 11-26-2005 11:43 --- In WanderlodgeForum@yahoogroups.com, "fwernlein" >Frank-- I enjojed your piece on winter camping.Ive only had my bb since june. Have never Traveled in winter. My previous rig (Tioga) could be dry camped for weeks with out draining batt. I go to Colo. fishing where there are no hookups. thanks for the post.-- Ed Gardels 89sp Arlington Tx. > I thought it might be worthwile to start a new thread on this topic of > winter travel. I would like to hear other opinions/experiences and > any cautions. > > I have had my bus through 2 winters, and use it for skiing trips and > other winter travel in VA/PA/NY. Some hook-up camping, most dry- > camping. Most of my experience is in the low teens as far as low > temps. > > Over the road: I have not had any big scares in snow/ice, I keep it > slow and reasonable(not hard in an FC). The bus can skid, and inspite > of the big weight, momentum on ice can surprise you. The bus stays > toasty with the chassis heat. We feel very safe and comfy. > > Camping: I have two modes (wet water lines OR dry) 1: WET: I keep the > fresh water tank filled as I expect to need it and I use on board > water. Basically, this is normal camping 2: DRY: I use bottled > water for sink and toilet flushing, thus only have to mess with > draining the waste tanks. I do not "dewinterize" the water supply > system. No showers...but you can maintain clean hands and face. For > either: I keep either rock salt or pink anti-freeze in the waste tanks. > > I run the generator typically for breakfast and dinner (microwave and > top off the batts), perhaps 30-45 mins both cycles-and always run long > enought to full operating temp. At night, I run the propane heaters, > usually deciding to use one or two based on the temp. forcast. Never > needed all three going. My goal is to keep both the family AND the > bus body interior warm (to prevent interior line freezing). I keep > the access door in the bath vanity open at night. I have run two of > the propane heaters with just batts overnight w/o problems (I have 6 > 6vt. golf batts). I do have an aux. CO detector that I installed. > > Main engine...I use the water block heater, and have battery blanket > heaters. Never had a cold start issue with the 3208. Typically, I > start the main at the end of my AM generator run... > > I think my biggest exposure to potential freezing problems is being > out of the bus for a extended time w/o electric hookup. If parked and > unattended/unheated...say for over 6+ hours, I would think the > interior temps would drop enough for line freezing if they > were "wet". This I try to avoid during below freezing weather. > > Frank > 85FC33 > Woodbridge, VA. > |
