"POOF" From LP Heater - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: "POOF" From LP Heater (/showthread.php?tid=1682) Pages: 1 2 |
"POOF" From LP Heater - erniecarpet@... - 12-10-2005 04:23 steve- get you a small wire brush and clean the probes inside the site glass. They get carbon on them and with a gentle cleaning will help them out. Ernie-83pt40 in Texas [Non-text portions of this message have been removed] "POOF" From LP Heater - erniecarpet@... - 12-10-2005 05:32 Steve- the site glass has a couple of wing nuts. It also has a gasket that become fragile with age- kinda like me. Ernie-83pt40 in thawing out texas [Non-text portions of this message have been removed] "POOF" From LP Heater - trvlngnrs - 12-10-2005 05:39 While outside, removing the polarity monitor, I noticed the bedroom LP heater would run for awhile then I would hear a "POOF". The heater would run for a few minutes and "POOF" again. I have already vacumed the areas I could get too, but really couldn't get to very much of the heater due to the metal box it's in. I've been told a couple times to clean it, but how? Do I need to disconnect the gas line and take it out? Is there a way to open up the heater box to clean inside it? TIA, Steve Harrie '86 PT38 "POOF" From LP Heater - guysmalley - 12-10-2005 06:30 --- In WanderlodgeForum@yahoogroups.com, "trvlngnrs" > > While outside, removing the polarity monitor, I noticed the bedroom LP > heater would run for awhile then I would hear a "POOF". The heater > would run for a few minutes and "POOF" again. > > I have already vacumed the areas I could get too, but really couldn't > get to very much of the heater due to the metal box it's in. > > I've been told a couple times to clean it, but how? Do I need to > disconnect the gas line and take it out? Is there a way to open up the > heater box to clean inside it? > > TIA, > Steve Harrie > '86 PT38 > Steve I assume you tried to reset the gas monitor? sometimes that will cut out the gas turn it off then on again guy smalley 86 pt40 "POOF" From LP Heater - trvlngnrs - 12-10-2005 08:51 > Steve I assume you tried to reset the gas monitor? sometimes that will cut out the gas turn it off then on again Nope Guy, I didn't do that. Do you mean the propane detector with the red button, on the floor by the refer, that connects to the LP tank solenoid? Or is there another switch? I had 2 furnaces on, only the rear was making the noise, thats why i figured it was just dirty. I just can't get into it. I unscrewed the grill on the front and tried sticking the narrow vacumn attatchment as far as it would go, but it wasn't very far. Steve '86 PT38 "POOF" From LP Heater - dhardy1944 - 12-10-2005 09:26 I noticed this week that my rear LP heater will not come on at all. The kitchen heater as well front heater works great. I looked at it but didn't know how to get into it or what to do first. It has been cold in Oklahoma. Dave in Tulsa (84PT40) --- In WanderlodgeForum@yahoogroups.com, "trvlngnrs" < nicodemus815@c...> wrote: > > > Steve I assume you tried to reset the gas monitor? sometimes that > will cut out the gas turn it off then on again > > Nope Guy, I didn't do that. Do you mean the propane detector with the > red button, on the floor by the refer, that connects to the LP tank > solenoid? Or is there another switch? > > I had 2 furnaces on, only the rear was making the noise, thats why i > figured it was just dirty. I just can't get into it. I unscrewed the > grill on the front and tried sticking the narrow vacumn attatchment as > far as it would go, but it wasn't very far. > > Steve > '86 PT38 > "POOF" From LP Heater - trvlngnrs - 12-10-2005 10:10 > steve- get you a small wire brush and clean the probes inside the site glass. Thanks Ernie, I'll do that. Does the site glass just unscrew, or is there a trick to it. The PT is not stored at my house, so I can't go check:-( Steve St. George "POOF" From LP Heater - Curt Sprenger - 12-10-2005 11:27 Steve, glad you brought up LP heaters. We've never used our LP heaters. However, during the next couple months they will be needed when camped out in the desert. With tank valve open, do I set the dash switch to LP ON, and set the thermostats to the desired temp? Something more? I'll attempt to clean them first. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. "POOF" From LP Heater - trvlngnrs - 12-10-2005 13:04 > We've never used our LP heaters. However, during the next couple months they will be needed when camped out in the desert. With tank valve open, do I set the dash switch to LP ON, and set the thermostats to the desired temp? Something more? I'll attempt to clean them first. Ha, are you brave! Asking me for help. Here is what I've figured out so far: * Propane tank on. * LP detector on. * Dash LP switch has to be on to provide 12 volt to the ignitor. * Each furnace has it's own thermostat, each one of these must be on (small lever on the bottom). * Set desired temp. * Stand outside:-) (I used to work in a burn unit) Steve Harrie "POOF" From LP Heater - Curt Sprenger - 12-10-2005 14:44 Thank you Steve. I'll follow your input...and run outside. Probable start with the bedroom heater. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. trvlngnrs wrote: > > We've never used our LP heaters. However, during the next couple > months they will be needed when camped out in the desert. With tank > valve open, do I set the dash switch to LP ON, and set the thermostats > to the desired temp? Something more? I'll attempt to clean them first. > > > Ha, are you brave! Asking me for help. Here is what I've figured out > so far: > > * Propane tank on. > * LP detector on. > * Dash LP switch has to be on to provide 12 volt to the ignitor. > * Each furnace has it's own thermostat, each one of these must be on > (small lever on the bottom). > * Set desired temp. > * Stand outside:-) (I used to work in a burn unit) > > Steve Harrie > > > > > > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O\ bWmSYTw> > Wanderlodge > <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wan\ derlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea\ tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ> > Automotive maintenance > <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34\ cC1O9CxA> > > Recreational vehicle dealer > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY\ HfELr6o72IW1A> > Used recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational+\ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer\ &w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-\ kXbDI4ZSadEw> > Automotive radiators > <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehicl\ es&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us\ ed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq\ _4GlXA> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
