Water Pump Keeps Running - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Water Pump Keeps Running (/showthread.php?tid=1719) |
Water Pump Keeps Running - Rob Robinson - 12-18-2005 15:29 I seem to have a water pump that keeps running. I have the two pump system with the bathroom switch that lets you select pump A or pump B or both. When I select pump B or both A & B the system continues to run. Is there a pressure switch that could have gone south and if so can anyone tell me what it looks like and maybe where it might be located. If not a pressure switch could it be some other gold plated wangflanger part. Rob 94 wlwb Water Pump Keeps Running - Fred Hulse - 12-18-2005 16:15 Rob Make certain your fresh water fill switch hasn't been accidently switched to fill, this will cause your pump to run on. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 Water Pump Keeps Running - Rob Robinson - 12-18-2005 16:23 Thanks Fred. I've made that mistake before all right. No it's not the fill switch. Only the one pump runs on while the other works properly. Rob, Sue & Merlin 94 WLWB Quoting Fred Hulse > > > > > Rob > > Make certain your fresh water fill switch hasn't been accidently switched to > > fill, this will cause your pump to run on. > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge PT41 > > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > Water Pump Keeps Running - George Lowry - 12-18-2005 16:53 Hi Rob, The pressure switch is located on the end of the pump - has two wires going to it, one from power and the other to the pump motor. The switch is available separately from most RV suppliers. George Lowry '95 WBDA 4203 Spearfish, SD. Rob Robinson wrote: >I seem to have a water pump that keeps running. I have the two pump >system with the bathroom switch that lets you select pump A or pump B >or both. When I select pump B or both A & B the system continues to >run. Is there a pressure switch that could have gone south and if so >can anyone tell me what it looks like and maybe where it might be >located. If not a pressure switch could it be some other gold plated >wangflanger part. > >Rob 94 wlwb > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > -- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.371 / Virus Database: 267.14.1/206 - Release Date: 12/16/2005 Water Pump Keeps Running - Rob Robinson - 12-18-2005 23:59 Thanks George I'm going to try and adjust that pressure switch and will let you know if I'm successful. Rob, Sue & Merlin 94 WLWB Quoting George Lowry > > > > > Hi Rob, > > > > The pressure switch is located on the end of the pump - has two wires > > going to it, one from power and the other to the pump motor. The switch > > is available separately from most RV suppliers. > > > > George Lowry > > '95 WBDA 4203 > > Spearfish, SD. > > > > Rob Robinson wrote: > > > > >I seem to have a water pump that keeps running. I have the two pump > > >system with the bathroom switch that lets you select pump A or pump B > > >or both. When I select pump B or both A & B the system continues to > > >run. Is there a pressure switch that could have gone south and if so > > >can anyone tell me what it looks like and maybe where it might be > > >located. If not a pressure switch could it be some other gold plated > > >wangflanger part. > > > > > >Rob 94 wlwb > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > No virus found in this outgoing message. > > Checked by AVG Free Edition. > > Version: 7.1.371 / Virus Database: 267.14.1/206 - Release Date: 12/16/2005 > > > > > > > > > > > > > > SPONSORED LINKS > > > > > Recreational vehicles > > > Wanderlodge > > > Automotive maintenance > > > > > Recreational vehicle dealer > > > Used recreational vehicles > > > Automotive radiators > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > Water Pump Keeps Running - Richard Hayden - 12-19-2005 15:18 Failure of the Sporlan fill valve AND/OR failure of the hot water tank drain valve will also cause this symtom. I faught this for months before I found that both were defective. However, this was on a one pump system. So may not apply to a 2 pump system as in the newer BB's. Dick Hayden '87 PT 38 - Lk Stevens, WA ----- Original Message ----- From: Fred Hulse To: WanderlodgeForum@yahoogroups.com Sent: Sunday, December 18, 2005 8:15 PM Subject: Re: [WanderlodgeForum] Water Pump Keeps Running Rob Make certain your fresh water fill switch hasn't been accidently switched to fill, this will cause your pump to run on. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge PT41 ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum<http://groups.yahoo.com/group/WanderlodgeForum>" on the web b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service<http://docs.yahoo.com/info/terms/>. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] Water Pump Keeps Running - Rob Robinson - 12-21-2005 10:38 Problem seems to be solved. I had some air in the line and when I openned a drain valve it expelled air and the pump immediately shut off. It cycles correctly now. Thanks to all for your help. Rob, Sue & Merlin 94 WLWB |
