Carbon Monxide Sensor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Carbon Monxide Sensor (/showthread.php?tid=1771) |
Carbon Monxide Sensor - Curt Sprenger - 12-29-2005 16:51 I'm getting ready to try the propane heaters to see if they work. Does the 1987 PT38 come from the factory with a Carbon Monoxide sensor? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Carbon Monxide Sensor - Jeff Miller - 12-30-2005 03:48 Yes and no. The sensor behind your breaker panel is listed as a CO sensor, but it is intended to detect a fire in the breaker panel and nothing else (assuming it is working properly), tied to the LP sensor panel. There is no original CO sensor for the heating system. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > I'm getting ready to try the propane heaters to see if they work. Does > the 1987 PT38 come from the factory with a Carbon Monoxide sensor? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > Carbon Monxide Sensor - Curt Sprenger - 12-30-2005 04:58 Thank you Jeff. Next questions - Has anyone experience with the battery operated CO sensor vs the hard wired? Wal-Mart sells a battery sensor. Camping World sells a hard wired sensor. Is one CO sensor enough? Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Jeff Miller wrote: > Yes and no. The sensor behind your breaker panel is listed as a CO > sensor, but it is intended to detect a fire in the breaker panel and > nothing else (assuming it is working properly), tied to the LP sensor > panel. > > There is no original CO sensor for the heating system. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > I'm getting ready to try the propane heaters to see if they work. > Does > > the 1987 PT38 come from the factory with a Carbon Monoxide sensor? > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > Carbon Monxide Sensor - Jeff Miller - 12-30-2005 05:57 The hard-wired doesn't need batteries every year, and some of them allow dual-power sources (APU battery & engine batteries for example). I don't know if it is still made, but I have installed a combination LP/CO detector to replace the original one (I believe it became factory/standard in '88) which included an LP shutoff. LP and CO are both heavier than air, makes a good dual-sensor under the refrigerator. I also feel more comfortable with a digital-readout type (110vac + internal battery) such as the NightHawk brand from Menards et al just for a "warm fuzzy" feeling, as a back-up. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Thank you Jeff. > > Next questions - Has anyone experience with the battery operated CO > sensor vs the hard wired? Wal-Mart sells a battery sensor. Camping World > sells a hard wired sensor. Is one CO sensor enough? > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > Jeff Miller wrote: > > > Yes and no. The sensor behind your breaker panel is listed as a CO > > sensor, but it is intended to detect a fire in the breaker panel and > > nothing else (assuming it is working properly), tied to the LP sensor > > panel. > > > > There is no original CO sensor for the heating system. > > > > - Jeff Miller > > in Holland, MI > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > > > > I'm getting ready to try the propane heaters to see if they work. > > Does > > > the 1987 PT38 come from the factory with a Carbon Monoxide sensor? > > > > > > Curt Sprenger 1987 PT38, Anaheim Hills, Calif. > > > > > > > > > > > > > > > ------------------------------------------------------------------ ------ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > > > * To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > > Service <http://docs.yahoo.com/info/terms/>. > > > > > > ------------------------------------------------------------------ ------ > > > |
