Cruise Control Actuator Vacumm Control Unit (Mounted on right side looking Aft) - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Cruise Control Actuator Vacumm Control Unit (Mounted on right side looking Aft) (/showthread.php?tid=1805) |
Cruise Control Actuator Vacumm Control Unit (Mounted on right side looking Aft) - Jon - 01-06-2006 16:38 I would like to know if the chain that attaches to the back of the bellow of the Vacuum control unit should be a tight fit or hung loose with a little slop. I suspect that the chain should be attached tight but when I first started to work on this unit the chain had about a 1/4 to 3/8 slack in it. If anyone knows where I can get a bellow for my Vacuum control that mounts on the engine could they give an idea where I could order one from. The old one I have repaired by putting a small rubber patch on area that had rub on the steel attachment area was leaking at that point. This whole area runs around in a circle and has numerous cracks in it. I also spread some RTV in this cracked area and it seems to hold when I put a suction on the bellow. But it would be nice to have a new unit but can I get one? Jon |
