No City Water In Bus... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: No City Water In Bus... (/showthread.php?tid=1806) |
No City Water In Bus... - orbitalsolutions - 01-06-2006 19:07 I had my FC connected to city water. Everything worked fine this morning. I went back to the bus several hours later and there was no water, at any tap. I have pressure at the city water hook-up at the bus. Seems like it is cloged somewhere. Any thoughts? I turned off the pressured water and had to leave. I'll be able to get back to it Sunday and see what I can find. -James 78FC33SB Las Vegas NV No City Water In Bus... - dthollis1961 - 01-07-2006 02:53 James, There is a screen and a check valve where you connect the hose to the bus. David Hollis Springfield,IL Former owner of James' 78 FC33 --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > I had my FC connected to city water. Everything worked fine this > morning. I went back to the bus several hours later and there was no > water, at any tap. > > I have pressure at the city water hook-up at the bus. Seems like it is > cloged somewhere. > > Any thoughts? I turned off the pressured water and had to leave. I'll > be able to get back to it Sunday and see what I can find. > > > -James > 78FC33SB > Las Vegas NV > No City Water In Bus... - Ralph L. Fullenwider - 01-08-2006 03:40 Hi James: Check the input screen where you hook up the city water, it can be stopped up. If nothing found, then replacing the pressure regulator may be needed. Get one from BB but you don't have to replace the entire housing. On each side of the regulator in the housing in your Coach, there are 2 small round holes. Taking a large set of external snap ring pliers, insert the prongs on each side of the regulator in the holes and un screw the regulator. There will be a spring in there so be careful. Then do the same with the new regulator and lube it lightly with some white grease or petroleum jelly and insert the new regulator into the old housing. About a 10 minute job in all. Also you might check the air blow out switch to be sure it is not in the on position. The 2 way valve at the input of your water heater can do this as well. You can remove the 4 screws on the end cap facing the front of the Coach and that will expose the shuttle. With a pair of needle nose pliers, pull in the end of the shuttle to free it, then push on it a few times and be sure that it seats properly, replace the end cap and that is done. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 07:07 AM 1/7/2006 +0000, you wrote: >I had my FC connected to city water. Everything worked fine this >morning. I went back to the bus several hours later and there was no >water, at any tap. > >I have pressure at the city water hook-up at the bus. Seems like it is >cloged somewhere. > >Any thoughts? I turned off the pressured water and had to leave. I'll >be able to get back to it Sunday and see what I can find. > > >-James >78FC33SB >Las Vegas NV > > > No City Water In Bus... - orbitalsolutions - 01-08-2006 12:54 Thanks, Dave and Ralph. I replaced a clogged screen at the inlet connection and the water is running freely again. James 78FC33SB Las Vegas NV |
