More air spring questions - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: More air spring questions (/showthread.php?tid=1815) |
More air spring questions - Scott Forman - 01-08-2006 11:23 I may have answered my own question about my leaning coach...I have found that one of my left front air bags is ripped. I assume if one of the two bags at a given wheel is bad, then that corner would not inflate to the proper ride height....correct? Where can I find replacement air springs? How big a project is it to change those out? Thanks Scott Forman 'Tiger Pride' 82 FC35RB Memphis More air spring questions - George Lowry - 01-08-2006 12:27 Check a truck supply house or Napa or other sources... Get the number off the bag or from your book if you have it. BB is also a possible place. I also like Mohawk Mfg. & Supply in Des Plaines... My wife and another gal changed six of the bags on her coach when I was laid up after surgery. It is not too difficult. Probably will have to replace some bolts because the old ones may snap because of rust. Those are cheap. If you are reasonable handy with tools, no big job,' George Lowry '95 WBDA 4203 Spearfish, SD Currently enjoying warm dry weather in Indio, CA. Waiting for the Western Area FMCA rally to start... Scott Forman wrote: >I may have answered my own question about my leaning coach...I have >found that one of my left front air bags is ripped. I assume if one of >the two bags at a given wheel is bad, then that corner would not >inflate to the proper ride height....correct? > >Where can I find replacement air springs? How big a project is it to >change those out? > >Thanks >Scott Forman >'Tiger Pride' >82 FC35RB >Memphis > > > > > > >Yahoo! Groups Links > > > > > > > > > > > More air spring questions - Scott Forman - 01-08-2006 12:34 George, Can you give me a basic idea how the spings come out? I'm a fairly handy guy, but I have never worked on these. I can generally figure something out if I can get a diagram or some insructions. Thanks, Scott --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > > Check a truck supply house or Napa or other sources... Get the number > off the bag or from your book if you have it. BB is also a possible > place. I also like Mohawk Mfg. & Supply in Des Plaines... > > My wife and another gal changed six of the bags on her coach when I was > laid up after surgery. It is not too difficult. Probably will have to > replace some bolts because the old ones may snap because of rust. Those > are cheap. If you are reasonable handy with tools, no big job,' > > George Lowry > '95 WBDA 4203 > Spearfish, SD Currently enjoying warm dry weather in Indio, CA. > Waiting for the Western Area FMCA rally to start... > > > Scott Forman wrote: > > >I may have answered my own question about my leaning coach...I have > >found that one of my left front air bags is ripped. I assume if one of > >the two bags at a given wheel is bad, then that corner would not > >inflate to the proper ride height....correct? > > > >Where can I find replacement air springs? How big a project is it to > >change those out? > > > >Thanks > >Scott Forman > >'Tiger Pride' > >82 FC35RB > >Memphis > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > More air spring questions - George Lowry - 01-08-2006 13:34 Hi Scott, The exact mounting can and will vary. Usually one end of the bag will be attached to a mounting plate which is attached with four bolts. This is usually the upper plate. The bottom is normally attached to the plate on the axle with two bolts. There is an airline connection, normally on the top. With the age of your coach, it will probably be 1/4" copper tubing. That will have to be removed before the bag assembly can be removed. Since the bag is ripped or blown, that side will be completely flat. You will probably find it easier to remove and replace if you use a small hydraulic jack and jack up the body from the axle - then block it. I usually found that getting to the air fitting on the top to be the hardest part of the job. I recommend that you consider changing that copper tube with 1/4" plastic air brake line. It cuts with a pocket knife and is easy to route and connect. You will have to get the appropriate fittings for your situation. I preferred to get the air spring assembly rather than just the bag. Disassembly and reassembly can be tricky whereas the assembly will bolt in. I have never changed bags on your model coach, however I have found most to be very similar. Hopefully this will help you. George Lowry '95 WBDA 4203 Spearfish, SD Scott Forman wrote: >George, > >Can you give me a basic idea how the spings come out? I'm a fairly >handy guy, but I have never worked on these. I can generally figure >something out if I can get a diagram or some insructions. > >Thanks, >Scott > >--- In WanderlodgeForum@yahoogroups.com, George Lowry >wrote: > > >>Check a truck supply house or Napa or other sources... Get the >> >> >number > > >>off the bag or from your book if you have it. BB is also a >> >> >possible > > >>place. I also like Mohawk Mfg. & Supply in Des Plaines... >> >>My wife and another gal changed six of the bags on her coach when I >> >> >was > > >>laid up after surgery. It is not too difficult. Probably will >> >> >have to > > >>replace some bolts because the old ones may snap because of rust. >> >> >Those > > >>are cheap. If you are reasonable handy with tools, no big job,' >> >>George Lowry >>'95 WBDA 4203 >>Spearfish, SD Currently enjoying warm dry weather in Indio, CA. >>Waiting for the Western Area FMCA rally to start... >> >> >>Scott Forman wrote: >> >> >> >>>I may have answered my own question about my leaning coach...I >>> >>> >have > > >>>found that one of my left front air bags is ripped. I assume if >>> >>> >one of > > >>>the two bags at a given wheel is bad, then that corner would not >>>inflate to the proper ride height....correct? >>> >>>Where can I find replacement air springs? How big a project is it >>> >>> >to > > >>>change those out? >>> >>>Thanks >>>Scott Forman >>>'Tiger Pride' >>>82 FC35RB >>>Memphis >>> >>> >>> >>> >>> >>> >>>Yahoo! Groups Links >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> > > > > > > > >Yahoo! Groups Links > > > > > > > > > > |
