20" HDTV LCD - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 20" HDTV LCD (/showthread.php?tid=1819) |
20" HDTV LCD - trvlngnrs - 01-09-2006 10:45 I just bought this TV at Sears. I was looking at the new 19" Sony on sale for $799 (reg $999) and noticed this. It was marked $479 (reg $799) but when the salesman checked the computer it came up as $399. Anyone thinking of putting in a HDTV should check this out while supplies last!! It is the 4:3 aspect ratio, not the 16:9, that the salesman told me, but for the price I think it's pretty good. http://www.apexdigitalinc.com/proddetail.asp?category=HDTV&subcat=&linenumber=80 Steve Harrie Trying to Figure Out how To Install It '86 PT38 20" HDTV LCD - Curt Sprenger - 01-09-2006 11:51 Steve, I'm not familiar with the '86 but will assume the new TV is replacing the old one that is mounted center in the overhead. I used the original mounting to install our 15" LCD TV with bottom speaker. You will be able to determine if the original mounting can be used or modified to work. I'll send a couple pictures too. Remove the dash panels on either side and remove the TV. Our old TV was held in place at the upper corners of the mounting brackets that are exposed with the panels removed, one screw at each corner. It rested in a ledge at the bottom. Have someone hold the TV in place when removing the screws, or be sure to have a hand on it so it wont fall. On a table remove the TV from the mounting brackets. Lay the mounting face down on the table (on a packing blanket or similar). Place the new TV on top face down, marked the TV outline, and cut those steel side plates. Put this back on the table. The new TV should drop through to the blanket. Prop up the brackets/TV so the TV sticks through the mounting frame to be flush with the dash partitions. Weight down the assemble to keep it in place. Then use silicone around the TV/frame work, let it set up for a day, and mount the TV in the coach. I used some of the original vinyl that was part of the old TV unit, wrapped foam and the vinyl around cut to length/width wood sticks, to make up the dash filler around the new TV. Use Velcro to hold the pieces in place. I did this because the controls on the TV itself are located in the TV side and thought that some day I my need to get at them. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. trvlngnrs wrote: > I just bought this TV at Sears. I was looking at the new 19" Sony on > sale for $799 (reg $999) and noticed this. It was marked $479 (reg > $799) but when the salesman checked the computer it came up as $399. > > Anyone thinking of putting in a HDTV should check this out while > supplies last!! It is the 4:3 aspect ratio, not the 16:9, that the > salesman told me, but for the price I think it's pretty good. > > http://www.apexdigitalinc.com/proddetail.asp?category=HDTV&subcat=&linenumber=80 > > Steve Harrie > Trying to Figure Out how To Install It > '86 PT38 > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > 20" HDTV LCD - trvlngnrs - 01-09-2006 16:20 > I just bought this TV at Sears. http://www.apexdigitalinc.com/proddetail.asp?category=HDTV&subcat=&linenumber=80 Thanks for the details and pictures Curt. Your setup looks good! Our interiors look pretty much the same, except I have a VCR stuck in the panel over the driver's head. --------------------- The TV picture looked good during the day, but tonight I noticed it had brighter edges causing an hourglass discoloration. I'm going to bring it back to Sears tomorrow. The discoloration wasn't apparant during the brighter daylight hours. It is unacceptable since we normally watch TV at night. Steve Harrie '86 PT38 |
