Propane outlet - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Propane outlet (/showthread.php?tid=1856) |
Propane outlet - Brian Gatley - 01-16-2006 14:23 There is a quick connect for propane on the opposite side of the coach from the propane fill. My understanding, if I understand correctly, is that BBQs are high pressure appliances and need a high pressure supply of propane. Does anyone know if the quick connect connection is high pressure? Do I have to have a custom hose made to go from the propane quick connect to the connection at my BBQ (same one that uses the small throw away tanks)? Are there stock hoses available for this? Brian Gatley 93 WLWB PT40 Bend, OR [Non-text portions of this message have been removed] Propane outlet - Curt Sprenger - 01-16-2006 14:33 For our old coach, I went to the local propane supplier (distributor) and they made up multiple connections and hoses for me. I had a need to run 3 appliances at one time. The existing propane regulator on you Bird should be all the is needed for BBQ pressure, and the hose and connector. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Brian Gatley wrote: > There is a quick connect for propane on the opposite side of the coach > from the propane fill. My understanding, if I understand correctly, is > that BBQs are high pressure appliances and need a high pressure supply > of propane. Does anyone know if the quick connect connection is high > pressure? Do I have to have a custom hose made to go from the propane > quick connect to the connection at my BBQ (same one that uses the small > throw away tanks)? Are there stock hoses available for this? > > Brian Gatley > 93 WLWB PT40 > Bend, OR > > > [Non-text portions of this message have been removed] > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > Propane outlet - Jay Darst - 01-16-2006 15:14 Brian, My 85 PT40 had a regulator mouted directly after the main shut-off valve for the propane tank. Then the propane line went to another regulator, and then to a on/off valve, then to a quick connect. I made up some propane lines and tried to run my Coleman gas cook stove, gas grill, or Coleman propane lantern. The factory setup wouldn't provide enough gas for any one of the above appliances, not enough gas. So, I removed the second regulator, the regulator just before the vavle that controls the propane to the quick coupler. I also re-arranged the line that feeds the quick coupler so as it has "tank" pressure. Now any or all of the above appliances can be powered by the quick coupler. Have pictures if you want... Jay Darst 85PT40 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, "Brian Gatley" wrote: > > There is a quick connect for propane on the opposite side of the coach > from the propane fill. My understanding, if I understand correctly, is > that BBQs are high pressure appliances and need a high pressure supply > of propane. Does anyone know if the quick connect connection is high > pressure? Do I have to have a custom hose made to go from the propane > quick connect to the connection at my BBQ (same one that uses the small > throw away tanks)? Are there stock hoses available for this? > > Brian Gatley > 93 WLWB PT40 > Bend, OR > > > [Non-text portions of this message have been removed] > |
