valve lash on 3208 - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: valve lash on 3208 (/showthread.php?tid=1869) |
valve lash on 3208 - tom240842@... - 01-18-2006 09:12 When I had my injectors replaced 2 years ago at about 100,000 miles, because they already had all the 'tough stuff' off the top of the engine, I asked them to replace valve cover gaskets and adjust the valves. Only two valves were barely out of adjustment. Have a "good" 3208 mechanic listen to your engine and I will bet he can tell you if there is any adjustment needed. Tom Meservey USN (Ret) '81FC33' Charleston AFB [Non-text portions of this message have been removed] |
