origin of coolant leak from D60?? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: origin of coolant leak from D60?? (/showthread.php?tid=1927) |
origin of coolant leak from D60?? - luckyron1 - 01-31-2006 09:01 We have a slow coolant leak that I first noted after getting a low coolant warning upon start-up. I topped off the reservoir with the appropriate diesel 50/50 mix and it did go away, at least for about 700 miles or so. So, I added some more 50/50 and ran the engine for about an hour and checked it all around and underneath and no leaking at all. So, I shut it off, slipped a piece of clean cardboard beneath the block and this morning I noted a little puddle of coolant on the cardboard at the left forward part of the block, which is the radiator side on this bird--when viewed from the rear of the coach. It does appear to be coming from behing the block, away from the radiator. I know from looking at a basic D60 engine that the water pump isn't back there. Hoses?? Any ideas??? Thanks Ron & Ruth in 2000 LXI origin of coolant leak from D60?? - pgchd - 01-31-2006 09:21 On the "left side" of the engine (standing in front) there are 4 coolant hoses (about 4 inches long each) that have "double" clamps running parallel to the block (front to back), just above the "oil filters" and "bus air conditioner lines". I would suspect 1 of them has a "slight leak" and you can just tighen up the clamps. Pete and Donna Chin 95 42' - happened to me! --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > > We have a slow coolant leak that I first noted after getting a low > coolant warning upon start-up. I topped off the reservoir with the > appropriate diesel 50/50 mix and it did go away, at least for about 700 > miles or so. So, I added some more 50/50 and ran the engine for about > an hour and checked it all around and underneath and no leaking at > all. So, I shut it off, slipped a piece of clean cardboard beneath the > block and this morning I noted a little puddle of coolant on the > cardboard at the left forward part of the block, which is the radiator > side on this bird--when viewed from the rear of the coach. It does > appear to be coming from behing the block, away from the radiator. I > know from looking at a basic D60 engine that the water pump isn't back > there. Hoses?? Any ideas??? > > Thanks > > Ron & Ruth in 2000 LXI > origin of coolant leak from D60?? - George Lowry - 01-31-2006 09:24 Ron & Ruth, Had a similar problem - found a slightly loose hose clamp. Would only take about a 1/2 turn but it stopped the leak. Usually, the heat of the engine would evaporate the moisture before I could find it. Some are real hard to detect. I have found that toilet paper is great for detecting small leaks as it shows the slightest dampness. An old plumber's trick. George Lowry '06 Alpine Apex Former owner of '95 WBDA 4203 Spearfish, SD Currently enjoying the warmth of Palm Springs. luckyron1 wrote: >We have a slow coolant leak that I first noted after getting a low >coolant warning upon start-up. I topped off the reservoir with the >appropriate diesel 50/50 mix and it did go away, at least for about 700 >miles or so. So, I added some more 50/50 and ran the engine for about >an hour and checked it all around and underneath and no leaking at >all. So, I shut it off, slipped a piece of clean cardboard beneath the >block and this morning I noted a little puddle of coolant on the >cardboard at the left forward part of the block, which is the radiator >side on this bird--when viewed from the rear of the coach. It does >appear to be coming from behing the block, away from the radiator. I >know from looking at a basic D60 engine that the water pump isn't back >there. Hoses?? Any ideas??? > >Thanks > >Ron & Ruth in 2000 LXI > > > > > > >Yahoo! Groups Links > > > > > > > > > > > origin of coolant leak from D60?? - R J - 02-01-2006 02:20 Hey thank you! I'll air it up, extend the jacks, and have a close look at 'em. Ron & Ruth in 2000 lxi m having the oil and filters changed next week --- pgchd > On the "left side" of the engine (standing in front) > there are 4 > coolant hoses (about 4 inches long each) that have > "double" clamps > running parallel to the block (front to back), just > above the "oil > filters" and "bus air conditioner lines". I would > suspect 1 of them > has a "slight leak" and you can just tighen up the > clamps. > > Pete and Donna Chin > 95 42' - happened to me! > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "luckyron1" > > wrote: > > > > We have a slow coolant leak that I first noted > after getting a low > > coolant warning upon start-up. I topped off the > reservoir with the > > appropriate diesel 50/50 mix and it did go away, > at least for about 700 > > miles or so. So, I added some more 50/50 and ran > the engine for about > > an hour and checked it all around and underneath > and no leaking at > > all. So, I shut it off, slipped a piece of clean > cardboard beneath the > > block and this morning I noted a little puddle of > coolant on the > > cardboard at the left forward part of the block, > which is the radiator > > side on this bird--when viewed from the rear of > the coach. It does > > appear to be coming from behing the block, away > from the radiator. I > > know from looking at a basic D60 engine that the > water pump isn't back > > there. Hoses?? Any ideas??? > > > > Thanks > > > > Ron & Ruth in 2000 LXI > > > > > > > > origin of coolant leak from D60?? - R J - 02-06-2006 09:17 My thanks to all those that responded on this issue. I exercised the engine today and got underneath it and sure enough spotted a little leak that appears to be due to a loose hose clamp. Simple enough to fix if you can get to it but unfortunately there's another hose in the way and the clamp screw is pointed the wrong direction. I'll have a mechanic take care of it when I take it in for routine maintenance later this month. At least now I'm not in the position where they might be able to sell me a new water pump or something. Ha! --- George Lowry > Ron & Ruth, > > Had a similar problem - found a slightly loose hose > clamp. Would only > take about a 1/2 turn but it stopped the leak. > Usually, the heat of the > engine would evaporate the moisture before I could > find it. Some are > real hard to detect. I have found that toilet > paper is great for > detecting small leaks as it shows the slightest > dampness. An old > plumber's trick. > > George Lowry > '06 Alpine Apex Former owner of '95 WBDA 4203 > Spearfish, SD Currently enjoying the warmth of > Palm Springs. > > luckyron1 wrote: > > >We have a slow coolant leak that I first noted > after getting a low > >coolant warning upon start-up. I topped off the > reservoir with the > >appropriate diesel 50/50 mix and it did go away, at > least for about 700 > >miles or so. So, I added some more 50/50 and ran > the engine for about > >an hour and checked it all around and underneath > and no leaking at > >all. So, I shut it off, slipped a piece of clean > cardboard beneath the > >block and this morning I noted a little puddle of > coolant on the > >cardboard at the left forward part of the block, > which is the radiator > >side on this bird--when viewed from the rear of the > coach. It does > >appear to be coming from behing the block, away > from the radiator. I > >know from looking at a basic D60 engine that the > water pump isn't back > >there. Hoses?? Any ideas??? > > > >Thanks > > > >Ron & Ruth in 2000 LXI > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > |
