1979 FC35/ Fuel Guage Problem - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1979 FC35/ Fuel Guage Problem (/showthread.php?tid=1970) |
1979 FC35/ Fuel Guage Problem - coxcox2u - 02-09-2006 15:45 My fuel guage just quit working! When I turn the key on the guage pegs quickly full counter clockwise below empty. Does this indicate a short? Anyone else have a similar problem? Could it be the probe? Any info on troubleshooting this syatem would be helpful! Thanks! 1979 FC35/ Fuel Guage Problem - Byrne Lobdell - 02-10-2006 01:12 It is sounds like the sending unit. Under the rear bed on the floor about center of the coach you will find a round metal plate about six inches with screws around outside. Remove the plate and the sending unit in just below. Remove the wire from top of unit and the guage should go to empty, now ground the wire and the guage should go to full. I f this happens the guage is ok and the sending unit is bad. This is a universal unit and is avaible from NAPA. The only thing to pay attention to is the new unit float length has to be set to the same as old befor installing. Good luck, Byrne 77FC35 High and dry in Louisiana coxcox2u My fuel guage just quit working! When I turn the key on the guage pegs quickly full counter clockwise below empty. Does this indicate a short? Anyone else have a similar problem? Could it be the probe? Any info on troubleshooting this syatem would be helpful! Thanks! SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Mail Use Photomail to share photos without annoying attachments. [Non-text portions of this message have been removed] 1979 FC35/ Fuel Guage Problem - Chris Cox - 02-10-2006 10:37 Byrne, thanks so much for the info! You were a great help! Thanks! Byrne Lobdell unit. Under the rear bed on the floor about center of the coach you will find a round metal plate about six inches with screws around outside. Remove the plate and the sending unit in just below. Remove the wire from top of unit and the guage should go to empty, now ground the wire and the guage should go to full. I f this happens the guage is ok and the sending unit is bad. This is a universal unit and is avaible from NAPA. The only thing to pay attention to is the new unit float length has to be set to the same as old befor installing. Good luck, Byrne 77FC35 High and dry in Louisiana coxcox2u My fuel guage just quit working! When I turn the key on the guage pegs quickly full counter clockwise below empty. Does this indicate a short? Anyone else have a similar problem? Could it be the probe? Any info on troubleshooting this syatem would be helpful! Thanks! SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Mail Use Photomail to share photos without annoying attachments. [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] 1979 FC35/ Fuel Guage Problem - Tom Warner - 02-10-2006 14:57 Before you go to all of the trouble of pulling up the carpet and then uncapping the plate for the fuel sender etc, check the ground coming out of the plug for the dash. Its very possible that is where the problem is and not the float itself. tom Warner 1982 FC35 Vernon center,NY At 05:37 PM 2/10/2006, you wrote: >Byrne, thanks so much for the info! You were a great help! Thanks! > >Byrne Lobdell >the sending unit. Under the rear bed on the floor about center of >the coach you will find a round metal plate about six inches with >screws around outside. Remove the plate and the sending unit in just >below. Remove the wire from top of unit and the guage should go to >empty, now ground the wire and the guage should go to full. I f this >happens the guage is ok and the sending unit is bad. This is a >universal unit and is avaible from NAPA. The only thing to pay >attention to is the new unit float length has to be set to the same >as old befor installing. Good luck, Byrne > 77FC35 High and dry in Louisiana > >coxcox2u > My fuel guage just quit working! When I turn the key on the guage pegs >quickly full counter clockwise below empty. Does this indicate a short? >Anyone else have a similar problem? Could it be the probe? Any info on >troubleshooting this syatem would be helpful! Thanks! > > > > > > SPONSORED LINKS > Recreational vehicles Wanderlodge Automotive > maintenance Recreational vehicle dealer Used recreational > vehicles Automotive radiators > >--------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > >--------------------------------- > > > > > >--------------------------------- >Yahoo! Mail >Use Photomail to share photos without annoying attachments. > >[Non-text portions of this message have been removed] > > > > SPONSORED LINKS > Recreational vehicles Wanderlodge Automotive > maintenance Recreational vehicle dealer Used recreational > vehicles Automotive radiators > >--------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > >--------------------------------- > > > > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around ><http://mail.yahoo.com>http://mail.yahoo.com > >[Non-text portions of this message have been removed] > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreationa\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- 1979 FC35/ Fuel Guage Problem - Chris Cox - 02-11-2006 05:17 Thanks guys! I went down to NAPA, purchased the $35.00 universal sending unit with guage. Installed them in about one hour and everything works great now! Thanks again! Tom Warner pulling up the carpet and then uncapping the plate for the fuel sender etc, check the ground coming out of the plug for the dash. Its very possible that is where the problem is and not the float itself. tom Warner 1982 FC35 Vernon center,NY At 05:37 PM 2/10/2006, you wrote: >Byrne, thanks so much for the info! You were a great help! Thanks! > >Byrne Lobdell >the sending unit. Under the rear bed on the floor about center of >the coach you will find a round metal plate about six inches with >screws around outside. Remove the plate and the sending unit in just >below. Remove the wire from top of unit and the guage should go to >empty, now ground the wire and the guage should go to full. I f this >happens the guage is ok and the sending unit is bad. This is a >universal unit and is avaible from NAPA. The only thing to pay >attention to is the new unit float length has to be set to the same >as old befor installing. Good luck, Byrne > 77FC35 High and dry in Louisiana > >coxcox2u > My fuel guage just quit working! When I turn the key on the guage pegs >quickly full counter clockwise below empty. Does this indicate a short? >Anyone else have a similar problem? Could it be the probe? Any info on >troubleshooting this syatem would be helpful! Thanks! > > > > > > SPONSORED LINKS > Recreational vehicles Wanderlodge Automotive > maintenance Recreational vehicle dealer Used recreational > vehicles Automotive radiators > >--------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > >--------------------------------- > > > > > >--------------------------------- >Yahoo! Mail >Use Photomail to share photos without annoying attachments. > >[Non-text portions of this message have been removed] > > > > SPONSORED LINKS > Recreational vehicles Wanderlodge Automotive > maintenance Recreational vehicle dealer Used recreational > vehicles Automotive radiators > >--------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: >WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > >--------------------------------- > > > > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around ><http://mail.yahoo.com>http://mail.yahoo.com > >[Non-text portions of this message have been removed] > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreationa\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Mail Use Photomail to share photos without annoying attachments. [Non-text portions of this message have been removed] |
