Power Steering Fluid Check? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Power Steering Fluid Check? (/showthread.php?tid=1973) |
Power Steering Fluid Check? - coxcox2u - 02-12-2006 02:40 OK, been all through my manuals, my power stearing unit has a slight leak, where do I add the fluid on my 1979 35FC? Power Steering Fluid Check? - dspithaler@... - 02-12-2006 03:01 On my 79 FC Lift up the dog house & it was near the back to the left side. It is in a black can with a nut that holds the top on. Mine had a tee handle dip stick that screwed in the top to check the fluid level. Hopes this helps Don 89 SP 36' Butler, PA IN Cocoa Beach, FL right now. -----Original Message----- From: coxcox2u To: WanderlodgeForum@yahoogroups.com Sent: Sun, 12 Feb 2006 14:40:31 -0000 Subject: [WanderlodgeForum] Power Steering Fluid Check? OK, been all through my manuals, my power stearing unit has a slight leak, where do I add the fluid on my 1979 35FC? Yahoo! Groups Links [Non-text portions of this message have been removed] |
