Recomended Engine Oil - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Recomended Engine Oil (/showthread.php?tid=1974) |
Recomended Engine Oil - coxcox2u - 02-12-2006 04:22 My CAT Turbo 3208 is coming up on an oil change. What oils and weights do you recomend. I'm in the south so cold weather is not a factor. Thanks Recomended Engine Oil - dspithaler@... - 02-12-2006 05:03 I use Mobil Del-Vac 15W-40W all the year around in both of the Cats. I had a 3208 NA 210 & a 3208 TA 300. It works good for me. I keep mine a Quart low on fill up. It seems to use the first quart quicker. You can get it at Wal-Marts Cheaper than most retail stations By the way it is good to sign your port with year of coach & where you are located. Don 89 SP 36' Butler, PA In Cocoa FL right now -----Original Message----- From: coxcox2u To: WanderlodgeForum@yahoogroups.com Sent: Sun, 12 Feb 2006 16:22:05 -0000 Subject: [WanderlodgeForum] Recomended Engine Oil My CAT Turbo 3208 is coming up on an oil change. What oils and weights do you recomend. I'm in the south so cold weather is not a factor. Thanks Yahoo! Groups Links [Non-text portions of this message have been removed] Recomended Engine Oil - Stephen Birtles - 02-12-2006 06:27 Delo400 $46.00 a case at sams club Stephen --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > I use Mobil Del-Vac 15W-40W all the year around in both of the Cats. I had a 3208 NA 210 & a 3208 TA 300. It works good for me. I keep mine a Quart low on fill up. It seems to use the first quart quicker. You can get it at Wal-Marts Cheaper than most retail stations > By the way it is good to sign your port with year of coach & where you are located. > Don > 89 SP 36' > Butler, PA In Cocoa FL right now > > -----Original Message----- > From: coxcox2u > To: WanderlodgeForum@yahoogroups.com > Sent: Sun, 12 Feb 2006 16:22:05 -0000 > Subject: [WanderlodgeForum] Recomended Engine Oil > > > My CAT Turbo 3208 is coming up on an oil change. What oils and weights > do you recomend. I'm in the south so cold weather is not a factor. > Thanks > > > > > > > Yahoo! Groups Links > > > > > > > [Non-text portions of this message have been removed] > Recomended Engine Oil - Tom Warner - 02-12-2006 07:48 Delo 400 is a good motoroil no question about that, http://www.chevron.com/products/prodserv/nafl/trucking/content/prodspecs.shtm , but in my opinion Mobil Super 1300 , 15W-40 weight is better http://www.mobil.com/USA-English/Lubes/PDS/NAUSE2CVLMOMobil_Delvac_1300_Super.as\ p . In the 15W-40 weight Mobil Super 1300 meets ALL of the latest Diesel engine specifications for the most demanding uses. And the good part is that it is available also at Walmarts for $6.58/gal. I use it in my Cat3208NA, Honda Odyssey, Jeep Cherokee, Bolens Diesel tractor. It feels more like a synthetic to the touch then a dino oil. Tom Warner 1982 FC35 Vernon Center,NY At 01:27 PM 2/12/2006, you wrote: >Delo400 $46.00 a case at sams club >Stephen > > >--- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > > I use Mobil Del-Vac 15W-40W all the year around in both of the Cats. >I had a 3208 NA 210 & a 3208 TA 300. It works good for me. I keep >mine a Quart low on fill up. It seems to use the first quart quicker. >You can get it at Wal-Marts Cheaper than most retail stations > > By the way it is good to sign your port with year of coach & >where you are located. > > Don > > 89 SP 36' > > Butler, PA In Cocoa FL right now > > > > -----Original Message----- > > From: coxcox2u > > To: WanderlodgeForum@yahoogroups.com > > Sent: Sun, 12 Feb 2006 16:22:05 -0000 > > Subject: [WanderlodgeForum] Recomended Engine Oil > > > > > > My CAT Turbo 3208 is coming up on an oil change. What oils and weights > > do you recomend. I'm in the south so cold weather is not a factor. > > Thanks > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreationa\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Recomended Engine Oil - sfedeli3 - 02-12-2006 09:48 Just don't be puttin' that multi-viscocity stuff in a Detriot. They only will take straight 40W. 15W40 works great in the genny. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Delo 400 is a good motoroil no question about that, > http://www.chevron.com/products/prodserv/nafl/trucking/content/prodsp ecs.shtm > , but in my opinion Mobil Super 1300 , 15W-40 weight is better > http://www.mobil.com/USA- English/Lubes/PDS/NAUSE2CVLMOMobil_Delvac_1300_Super.asp > . In the 15W-40 weight Mobil Super 1300 meets ALL of the latest > Diesel engine specifications for the most demanding uses. And the > good part is that it is available also at Walmarts for $6.58/gal. I > use it in my Cat3208NA, Honda Odyssey, Jeep Cherokee, Bolens Diesel > tractor. It feels more like a synthetic to the touch then a dino oil. > > Tom Warner > 1982 FC35 > Vernon Center,NY > > > > > > > > > > > At 01:27 PM 2/12/2006, you wrote: > >Delo400 $46.00 a case at sams club > >Stephen > > > > > >--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > > > I use Mobil Del-Vac 15W-40W all the year around in both of the Cats. > >I had a 3208 NA 210 & a 3208 TA 300. It works good for me. I keep > >mine a Quart low on fill up. It seems to use the first quart quicker. > >You can get it at Wal-Marts Cheaper than most retail stations > > > By the way it is good to sign your port with year of coach & > >where you are located. > > > Don > > > 89 SP 36' > > > Butler, PA In Cocoa FL right now > > > > > > -----Original Message----- > > > From: coxcox2u > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Sun, 12 Feb 2006 16:22:05 -0000 > > > Subject: [WanderlodgeForum] Recomended Engine Oil > > > > > > > > > My CAT Turbo 3208 is coming up on an oil change. What oils and weights > > > do you recomend. I'm in the south so cold weather is not a factor. > > > Thanks > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > ><http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh n_ObWmSYTw>Recreational > >vehicles > ><http://groups.yahoo.com/gads? t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > ><http://groups.yahoo.com/gads? t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm y34cC1O9CxA>Automotive > >maintenance > ><http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah aeYHfELr6o72IW1A>Recreational > >vehicle dealer > ><http://groups.yahoo.com/gads? t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km 4L-kXbDI4ZSadEw>Used > >recreational vehicles > ><http://groups.yahoo.com/gads? t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT nMq_4GlXA>Automotive > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > Recomended Engine Oil - George Lowry - 02-12-2006 10:49 Shane, Need to clarify. What you have said is only for the two stroke Detroits. The four stroke Detroits utilize 15W-40 quite well. George Lowry '06 Alpine Apex - Formerly '95 WBDA 4203 Spearfish, SD Now at the Elks in Indio sfedeli3 wrote: >Just don't be puttin' that multi-viscocity stuff in a Detriot. They >only will take straight 40W. 15W40 works great in the genny. > >Shane Fedeli >85PT40 >Hershey, PA > > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner >wrote: > > >>Delo 400 is a good motoroil no question about that, >> >> >> >http://www.chevron.com/products/prodserv/nafl/trucking/content/prodsp >ecs.shtm > > >>, but in my opinion Mobil Super 1300 , 15W-40 weight is better >>http://www.mobil.com/USA- >> >> >English/Lubes/PDS/NAUSE2CVLMOMobil_Delvac_1300_Super.asp > > >>. In the 15W-40 weight Mobil Super 1300 meets ALL of the latest >>Diesel engine specifications for the most demanding uses. And the >>good part is that it is available also at Walmarts for $6.58/gal. >> >> >I > > >>use it in my Cat3208NA, Honda Odyssey, Jeep Cherokee, Bolens >> >> >Diesel > > >>tractor. It feels more like a synthetic to the touch then a dino >> >> >oil. > > >>Tom Warner >>1982 FC35 >>Vernon Center,NY >> >> >> >> >> >> >> >> >> >> >>At 01:27 PM 2/12/2006, you wrote: >> >> >>>Delo400 $46.00 a case at sams club >>>Stephen >>> >>> >>>--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: >>> >>> >>>>I use Mobil Del-Vac 15W-40W all the year around in both of the >>>> >>>> >Cats. > > >>>I had a 3208 NA 210 & a 3208 TA 300. It works good for me. I >>> >>> >keep > > >>>mine a Quart low on fill up. It seems to use the first quart >>> >>> >quicker. > > >>>You can get it at Wal-Marts Cheaper than most retail stations >>> >>> >>>> By the way it is good to sign your port with year of coach & >>>> >>>> >>>where you are located. >>> >>> >>>>Don >>>>89 SP 36' >>>>Butler, PA In Cocoa FL right now >>>> >>>>-----Original Message----- >>>>From: coxcox2u >>>>To: WanderlodgeForum@yahoogroups.com >>>>Sent: Sun, 12 Feb 2006 16:22:05 -0000 >>>>Subject: [WanderlodgeForum] Recomended Engine Oil >>>> >>>> >>>>My CAT Turbo 3208 is coming up on an oil change. What oils and >>>> >>>> >weights > > >>>>do you recomend. I'm in the south so cold weather is not a >>>> >>>> >factor. > > >>>>Thanks >>>> >>>> >>>> >>>> >>>> >>>> >>>>Yahoo! Groups Links >>>> >>>> >>>> >>>> >>>> >>>> >>>>[Non-text portions of this message have been removed] >>>> >>>> >>>> >>> >>> >>> >>> >>> >>>SPONSORED LINKS >>><http://groups.yahoo.com/gads? >>> >>> >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh >n_ObWmSYTw>Recreational > > >>>vehicles >>><http://groups.yahoo.com/gads? >>> >>> >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > >>><http://groups.yahoo.com/gads? >>> >>> >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm >y34cC1O9CxA>Automotive > > >>>maintenance >>><http://groups.yahoo.com/gads? >>> >>> >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah >aeYHfELr6o72IW1A>Recreational > > >>>vehicle dealer >>><http://groups.yahoo.com/gads? >>> >>> >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km >4L-kXbDI4ZSadEw>Used > > >>>recreational vehicles >>><http://groups.yahoo.com/gads? >>> >>> >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT >nMq_4GlXA>Automotive > > >>>radiators >>> >>> >>>---------- >>>YAHOO! GROUPS LINKS >>> >>> * Visit your group >>> >>> >>"<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" >> >> >on the web. > > >>> * >>> * To unsubscribe from this group, send an email to: >>> * >>> >>> >subject=Unsubscribe>WanderlodgeForum-unsubscribe@yahoogroups.com > > >>> * >>> * Your use of Yahoo! Groups is subject to the >>><http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. >>> >>> >>>---------- >>> >>> > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > Recomended Engine Oil - mbulriss - 02-12-2006 11:17 > Just don't be puttin' that multi-viscocity stuff in a Detriot. While that's an unqualified statement common to, and often repeated on all the forums, it's not true unless qualified. For Series 60 DD engines, multigrade is *required*. According to the Detroit Diesel Publication 7SE270, Specification Guide to Lubricating Oil, Fuel and Filters Requirements: 2.1.5 MONOGRADE OILS Monograde oils, irrespective of API service category, should not be used in on-road applications in any DDC 4-stroke engines or in off-road applications in Series 40E, 50, 60, MBE 900 and MBE 4000 engines. For two stroke DD (92 series), monograde is recommended, but use of multigrade is also allowed per the following portion of the guide on page 2-4: 4. At ambient temperatures below freezing (32° F or 0° C), sufficient starter cranking speed may not be achieved to start the engine with SAE 40 grade oils. Where starting aids are not available or at very cold temperatures (0° F to -25° F or -18° C to -32° C) even if starting aids are available, the use of multigrade SAE 15W-40 or monograde lubricant SAE 30 will improve startability. These lubricants must possess a High Temperature â High Shear Rate Viscosity (measured by ASTM D 4741 or equivalent) of 3.70 cP minimum. These oils must be replaced with monograde SAE 40 lubricants as soon as ambient conditions permit. (This same info was also in the DD series 92 manuals in my blue box) Further on the section on synthetics, the guide states (somewhat ambiguously on the two strokes): 3.7 SYNTHETIC OILS Synthetic oils should be used in Detroit Diesel engines provided they are API licensed and meet the performance and chemical requirements outlined in this publication. The oil should be a PGOS 93K214 approved product for use in EGR equipped engines. For two-stroke cycle engines, only synthetic oils which do not contain viscosity improver additives may be used. My personal interpretation on synthetics: Since most diesel synthetics are multi weight (15W-40) and far exceed the typical chemical and physical properties of a lubricant meeting Detroit Diesel requirements in normal applications, as defined in their table 3-2, it appears that multigrade synthetics meeting the spec are approved for use in the two strokes. FWIW..... Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: > > Just don't be puttin' that multi-viscocity stuff in a Detriot. They > only will take straight 40W. 15W40 works great in the genny. > > Shane Fedeli > 85PT40 > Hershey, PA > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > Delo 400 is a good motoroil no question about that, > > > http://www.chevron.com/products/prodserv/nafl/trucking/content/prodsp > ecs.shtm > > , but in my opinion Mobil Super 1300 , 15W-40 weight is better > > http://www.mobil.com/USA- > English/Lubes/PDS/NAUSE2CVLMOMobil_Delvac_1300_Super.asp > > . In the 15W-40 weight Mobil Super 1300 meets ALL of the latest > > Diesel engine specifications for the most demanding uses. And the > > good part is that it is available also at Walmarts for $6.58/gal. > I > > use it in my Cat3208NA, Honda Odyssey, Jeep Cherokee, Bolens > Diesel > > tractor. It feels more like a synthetic to the touch then a dino > oil. > > > > Tom Warner > > 1982 FC35 > > Vernon Center,NY > > > > > > > > > > > > > > > > > > > > > > At 01:27 PM 2/12/2006, you wrote: > > >Delo400 $46.00 a case at sams club > > >Stephen > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > > > > > I use Mobil Del-Vac 15W-40W all the year around in both of the > Cats. > > >I had a 3208 NA 210 & a 3208 TA 300. It works good for me. I > keep > > >mine a Quart low on fill up. It seems to use the first quart > quicker. > > >You can get it at Wal-Marts Cheaper than most retail stations > > > > By the way it is good to sign your port with year of coach & > > >where you are located. > > > > Don > > > > 89 SP 36' > > > > Butler, PA In Cocoa FL right now > > > > > > > > -----Original Message----- > > > > From: coxcox2u > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Sun, 12 Feb 2006 16:22:05 -0000 > > > > Subject: [WanderlodgeForum] Recomended Engine Oil > > > > > > > > > > > > My CAT Turbo 3208 is coming up on an oil change. What oils and > weights > > > > do you recomend. I'm in the south so cold weather is not a > factor. > > > > Thanks > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > >SPONSORED LINKS > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge& > w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr > eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzh > n_ObWmSYTw>Recreational > > >vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot > ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+v > ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge > &w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec > reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pm > y34cC1O9CxA>Automotive > > >maintenance > > ><http://groups.yahoo.com/gads? > t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wander > lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use > d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xah > aeYHfELr6o72IW1A>Recreational > > >vehicle dealer > > ><http://groups.yahoo.com/gads? > t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderl > odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used > +recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km > 4L-kXbDI4ZSadEw>Used > > >recreational vehicles > > ><http://groups.yahoo.com/gads? > t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w > 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre > ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgT > nMq_4GlXA>Automotive > > >radiators > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > > Recomended Engine Oil - sfedeli3 - 02-12-2006 15:16 Sorry George, forgot that there were some newer birds with 4-stroke Detriots. Good call. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > > Shane, > > Need to clarify. What you have said is only for the two stroke > Detroits. The four stroke Detroits utilize 15W-40 quite well. > > George Lowry > '06 Alpine Apex - Formerly '95 WBDA 4203 > Spearfish, SD Now at the Elks in Indio > > sfedeli3 wrote: > > >Just don't be puttin' that multi-viscocity stuff in a Detriot. They > >only will take straight 40W. 15W40 works great in the genny. > > > >Shane Fedeli > >85PT40 > >Hershey, PA > > > > > >--- In WanderlodgeForum@yahoogroups.com, Tom Warner > >wrote: > > > > > >>Delo 400 is a good motoroil no question about that, > >> > >> > >> > >http://www.chevron.com/products/prodserv/nafl/trucking/content/prods p > >ecs.shtm > > > > > >>, but in my opinion Mobil Super 1300 , 15W-40 weight is better > >>http://www.mobil.com/USA- > >> > >> > >English/Lubes/PDS/NAUSE2CVLMOMobil_Delvac_1300_Super.asp > > > > > >>. In the 15W-40 weight Mobil Super 1300 meets ALL of the latest > >>Diesel engine specifications for the most demanding uses. And the > >>good part is that it is available also at Walmarts for $6.58/gal. > >> > >> > >I > > > > > >>use it in my Cat3208NA, Honda Odyssey, Jeep Cherokee, Bolens > >> > >> > >Diesel > > > > > >>tractor. It feels more like a synthetic to the touch then a dino > >> > >> > >oil. > > > > > >>Tom Warner > >>1982 FC35 > >>Vernon Center,NY > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >>At 01:27 PM 2/12/2006, you wrote: > >> > >> > >>>Delo400 $46.00 a case at sams club > >>>Stephen > >>> > >>> > >>>--- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > >>> > >>> > >>>>I use Mobil Del-Vac 15W-40W all the year around in both of the > >>>> > >>>> > >Cats. > > > > > >>>I had a 3208 NA 210 & a 3208 TA 300. It works good for me. I > >>> > >>> > >keep > > > > > >>>mine a Quart low on fill up. It seems to use the first quart > >>> > >>> > >quicker. > > > > > >>>You can get it at Wal-Marts Cheaper than most retail stations > >>> > >>> > >>>> By the way it is good to sign your port with year of coach & > >>>> > >>>> > >>>where you are located. > >>> > >>> > >>>>Don > >>>>89 SP 36' > >>>>Butler, PA In Cocoa FL right now > >>>> > >>>>-----Original Message----- > >>>>From: coxcox2u > >>>>To: WanderlodgeForum@yahoogroups.com > >>>>Sent: Sun, 12 Feb 2006 16:22:05 -0000 > >>>>Subject: [WanderlodgeForum] Recomended Engine Oil > >>>> > >>>> > >>>>My CAT Turbo 3208 is coming up on an oil change. What oils and > >>>> > >>>> > >weights > > > > > >>>>do you recomend. I'm in the south so cold weather is not a > >>>> > >>>> > >factor. > > > > > >>>>Thanks > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>>Yahoo! Groups Links > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>>[Non-text portions of this message have been removed] > >>>> > >>>> > >>>> > >>> > >>> > >>> > >>> > >>> > >>>SPONSORED LINKS > >>><http://groups.yahoo.com/gads? > >>> > >>> > >t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge & > >w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+rec r > >eational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dz h > >n_ObWmSYTw>Recreational > > > > > >>>vehicles > >>><http://groups.yahoo.com/gads? > >>> > >>> > >t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automo t > >ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+ v > >ehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z- > >8HJdysB3QLPj9U0JvqYQ>Wanderlodge > > > > > >>><http://groups.yahoo.com/gads? > >>> > >>> > >t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodg e > >&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+re c > >reational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8P m > >y34cC1O9CxA>Automotive > > > > > >>>maintenance > >>><http://groups.yahoo.com/gads? > >>> > >>> > >t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wande r > >lodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Us e > >d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xa h > >aeYHfELr6o72IW1A>Recreational > > > > > >>>vehicle dealer > >>><http://groups.yahoo.com/gads? > >>> > >>> > >t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wander l > >odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d > >+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5k m > >4L-kXbDI4ZSadEw>Used > > > > > >>>recreational vehicles > >>><http://groups.yahoo.com/gads? > >>> > >>> > >t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge& w > >3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recr e > >ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWg T > >nMq_4GlXA>Automotive > > > > > >>>radiators > >>> > >>> > >>>---------- > >>>YAHOO! GROUPS LINKS > >>> > >>> * Visit your group > >>> > >>> > >>"<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > >> > >> > >on the web. > > > > > >>> * > >>> * To unsubscribe from this group, send an email to: > >>> * > >>> > >>> > >subject=Unsubscribe>WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > >>> * > >>> * Your use of Yahoo! Groups is subject to the > >>><http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > >>> > >>> > >>>---------- > >>> > >>> > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > |
