Racor Help - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Racor Help (/showthread.php?tid=1995) |
Racor Help - erniecarpet@... - 02-15-2006 04:45 There is a knurled nut on the bottom of the racor. Unscrew that a little and some fuel will come out. Ernie-83pt40 in louisiana [Non-text portions of this message have been removed] Racor Help - Scott Forman - 02-15-2006 07:44 What maintenance does the Racor on my FC require? I know what a Racor does, but don't know much about the thing, and there's no manual in my Blue Box. Help? Scott Forman 82 FC35RB Memphis Racor Help - Jeff Miller - 02-15-2006 08:38 I can't remember the specified service interval, but if you don't have a "water in fuel" light, and the Racor gauge (to the right of your right knee in the carpeted engine cover) is in the green when at full- throttle, likely nothing other than a visual inspection to ensure that the bowl doesn't have sediment or water in the bottom of it. Occasionally draining a cup of fuel (while engine is running if equipped with the electric pump, without engine running if not) from the bottom of the bowl to check for contaminants. I change both fuel filters with every oil change, believe that the interval is actually twice that long, but it is a convenient time to dispose of all filters and fuel/oil. Again, changing the Racor on an electric-pump equipped FC ('83-up?) is a fairly simple matter as you change the filter, install the lid with the TEE-handle a turn or two loose, start the engine, and when fuel starts coming out of the top of the filter casing around the tee-nut you tighten the tee-nut. Self- priming. For the non-electric-boost-pump folks it is not this easy unfortunately, I remember it well. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > What maintenance does the Racor on my FC require? I know what a Racor > does, but don't know much about the thing, and there's no manual in my > Blue Box. Help? > > Scott Forman > 82 FC35RB > Memphis > Racor Help - Scott Forman - 02-15-2006 09:17 How do I get a sample from the bottom of the bowl? --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" wrote: > > I can't remember the specified service interval, but if you don't have > a "water in fuel" light, and the Racor gauge (to the right of your > right knee in the carpeted engine cover) is in the green when at full- > throttle, likely nothing other than a visual inspection to ensure that > the bowl doesn't have sediment or water in the bottom of it. > Occasionally draining a cup of fuel (while engine is running if > equipped with the electric pump, without engine running if not) from > the bottom of the bowl to check for contaminants. > > I change both fuel filters with every oil change, believe that the > interval is actually twice that long, but it is a convenient time to > dispose of all filters and fuel/oil. Again, changing the Racor on an > electric-pump equipped FC ('83-up?) is a fairly simple matter as you > change the filter, install the lid with the TEE-handle a turn or two > loose, start the engine, and when fuel starts coming out of the top of > the filter casing around the tee-nut you tighten the tee-nut. Self- > priming. For the non-electric-boost-pump folks it is not this easy > unfortunately, I remember it well. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > What maintenance does the Racor on my FC require? I know what a > Racor > > does, but don't know much about the thing, and there's no manual in > my > > Blue Box. Help? > > > > Scott Forman > > 82 FC35RB > > Memphis > > > Racor Help - fwernlein - 02-15-2006 12:22 Scott, look in "files" here or on Yahoo Wanderlodge FC for Racor info...has filter, service data. Frank 85FC33 Woodbridge, VA. --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > How do I get a sample from the bottom of the bowl? > > > > > > Scott Forman > > > 82 FC35RB > > > Memphis > > > > > > Racor Help - erniecarpet@... - 02-16-2006 04:18 Dave- absolutly, I always have the engine off when changing those filter. I can't imagine trying to prime this old Detroit. Ernie-83pt40 in louisiana- going to a Lone Star rally in TEXAS next week. [Non-text portions of this message have been removed] Racor Help - David Heibult - 02-16-2006 06:56 Ernie.make sure your engine is shut off prior to draining the water off the bottom of your racor filter.otherwise you will suck air into your injectors and can lose prime. Dave 91 WLPT 40 >From: erniecarpet@... >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Re: Racor Help >Date: Wed, 15 Feb 2006 16:45:32 EST > > > > > >There is a knurled nut on the bottom of the racor. Unscrew that a little >and > >some fuel will come out. Ernie-83pt40 in louisiana > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > > > > SPONSORED LINKS > > > > > Recreational vehicles > > > Wanderlodge > > > Automotive maintenance > > > > > Recreational vehicle dealer > > > Used recreational vehicles > > > Automotive radiators > > > > > > > > > > > > > > > > YAHOO! GROUPS LINKS > > > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > > > > > > > > > > > > |
