Two or three oil rings? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Two or three oil rings? (/showthread.php?tid=2015) |
Two or three oil rings? - Jon - 02-18-2006 15:41 I thought one of the problems with having a turbo installed an older 3208 engine that it only had two ring on the pistons. And the latter engines ran with three, I'm I right? And this can cause problems with only the two rings. Jon Rebel Bird 78 Wanderlodge Two or three oil rings? - Jeff Miller - 02-19-2006 09:43 The 3208Na, 3208Ta, and 3208ATAAC (Natural, Turbo, Air-To-Air- Aftercooled) all were 2-ring engines. The 3208 was designed as a two- ring engine, works fine that way. The amount of friction, cylinder wear, all work fine with two rings. The third ring was offered as a retrofit starting in the early-mid '80s as an answer to competitors in the replacement-parts industry offering a 3-ring piston for the 3208, ... nothing more. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I thought one of the problems with having a turbo installed an older > 3208 engine that it only had two ring on the pistons. And the latter > engines ran with three, I'm I right? And this can cause problems with > only the two rings. > > Jon > Rebel Bird > 78 Wanderlodge > Two or three oil rings? - Mike Hohnstein - 02-19-2006 12:51 Them 3 rings might have been an effort to stop the serious fog job from a cold start that "throwaways" were so famous for. Kinda hurt diesel image, like 5.7 GMs. Mike Hohnstein ----- Original Message ----- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Sunday, February 19, 2006 3:43 PM Subject: [WanderlodgeForum] Re: Two or three oil rings? The 3208Na, 3208Ta, and 3208ATAAC (Natural, Turbo, Air-To-Air- Aftercooled) all were 2-ring engines. The 3208 was designed as a two- ring engine, works fine that way. The amount of friction, cylinder wear, all work fine with two rings. The third ring was offered as a retrofit starting in the early-mid '80s as an answer to competitors in the replacement-parts industry offering a 3-ring piston for the 3208, ... nothing more. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I thought one of the problems with having a turbo installed an older > 3208 engine that it only had two ring on the pistons. And the latter > engines ran with three, I'm I right? And this can cause problems with > only the two rings. > > Jon > Rebel Bird > 78 Wanderlodge > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
