Got the steps working on the Rebel Bird - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Got the steps working on the Rebel Bird (/showthread.php?tid=2021) |
Got the steps working on the Rebel Bird - Jon - 02-19-2006 12:27 After checking everything under the sun on the operations of my Wanderlodge steps I noticed that there was power to both sides of the door switch (Button type). I checked a little closer and low and behold someone either from the factory or in the past put in a 12 volt heater strip right under the steps. I wouldn't have notice this but while checking under the coach I notice this item just sitting in a void area under the steps. It was wired up to the toggle switch and then to complete the circuit someone ran the negative part to the push button electric switch on the negative side. So what happen over time the heater strip probably due to age shorter out inside. So instead of a heating strip it was just routing the power from the toggle switch to the door switch (Negative side) I guess if I would have know anything about this wiring system I would have caught it but I just thought it was strange to have power on both sides of that switch but that maybe this was designed for a purpose. So now the steps go out and in with no problem and thanks for all the help I got here. PS I'm going to post a picture of my headache on Bruces site if anyone might be interest in seeing the "Heater Strip from Hell!" Jon Lechich X Marine Machinest Rebel Bird Bremerton Washington Got the steps working on the Rebel Bird - Tom Warner - 02-19-2006 13:45 Jon once again....I believe what you think is a heater strip is the safety device mounted under the sill of the door to protect your feet if the steps should inadvertently trigger and close, when the strip feels your feet pushing against it, it cuts power off to the steps. tom Warner 1982 FC35 Vernon Center,Ny At 07:27 PM 2/19/2006, you wrote: >After checking everything under the sun on the operations of my >Wanderlodge steps I noticed that there was power to both sides of the >door switch (Button type). I checked a little closer and low and >behold someone either from the factory or in the past put in a 12 >volt heater strip right under the steps. I wouldn't have notice this >but while checking under the coach I notice this item just sitting in >a void area under the steps. It was wired up to the toggle switch and >then to complete the circuit someone ran the negative part to the >push button electric switch on the negative side. So what happen >over time the heater strip probably due to age shorter out inside. >So instead of a heating strip it was just routing the power from the >toggle switch to the door switch (Negative side) I guess if I would >have know anything about this wiring system I would have caught it >but I just thought it was strange to have power on both sides of that >switch but that maybe this was designed for a purpose. So now the >steps go out and in with no problem and thanks for all the help I got >here. PS I'm going to post a picture of my headache on Bruces site >if anyone might be interest in seeing the "Heater Strip from Hell!" > >Jon Lechich >X Marine Machinest >Rebel Bird >Bremerton Washington > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreationa\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Got the steps working on the Rebel Bird - Jeff Miller - 02-19-2006 14:06 I believe that the "heater strip" that you're referring to is the pressure-sensitive switch that Tom Warner referred to in an earlier reply to your problem. It was designed (as he had mentioned) to prevent toe-pinch by stopping the step from pulling in if a foot touched the pressure switch. Is this stuck to the underside of the steel just above the step? Simply disconnecting it will allow the step to pull in, often by now they no longer work correctly. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Jon" > > After checking everything under the sun on the operations of my > Wanderlodge steps I noticed that there was power to both sides of the > door switch (Button type). I checked a little closer and low and > behold someone either from the factory or in the past put in a 12 > volt heater strip right under the steps. I wouldn't have notice this > but while checking under the coach I notice this item just sitting in > a void area under the steps. It was wired up to the toggle switch and > then to complete the circuit someone ran the negative part to the > push button electric switch on the negative side. So what happen > over time the heater strip probably due to age shorter out inside. > So instead of a heating strip it was just routing the power from the > toggle switch to the door switch (Negative side) I guess if I would > have know anything about this wiring system I would have caught it > but I just thought it was strange to have power on both sides of that > switch but that maybe this was designed for a purpose. So now the > steps go out and in with no problem and thanks for all the help I got > here. PS I'm going to post a picture of my headache on Bruces site > if anyone might be interest in seeing the "Heater Strip from Hell!" > > Jon Lechich > X Marine Machinest > Rebel Bird > Bremerton Washington > Got the steps working on the Rebel Bird - Jon - 02-19-2006 18:02 --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Jon once again....I believe what you think is a heater strip is the > safety device mounted under the sill of the door to protect your feet > if the steps should inadvertently trigger and close, when the strip > feels your feet pushing against it, it cuts power off to the steps. > > tom Warner > 1982 FC35 > Vernon Center,Ny > > At 07:27 PM 2/19/2006, you wrote: > >After checking everything under the sun on the operations of my > >Wanderlodge steps I noticed that there was power to both sides of the > >door switch (Button type). I checked a little closer and low and > >behold someone either from the factory or in the past put in a 12 > >volt heater strip right under the steps. I wouldn't have notice this > >but while checking under the coach I notice this item just sitting in > >a void area under the steps. It was wired up to the toggle switch and > >then to complete the circuit someone ran the negative part to the > >push button electric switch on the negative side. So what happen > >over time the heater strip probably due to age shorter out inside. > >So instead of a heating strip it was just routing the power from the > >toggle switch to the door switch (Negative side) I guess if I would > >have know anything about this wiring system I would have caught it > >but I just thought it was strange to have power on both sides of that > >switch but that maybe this was designed for a purpose. So now the > >steps go out and in with no problem and thanks for all the help I got > >here. PS I'm going to post a picture of my headache on Bruces site > >if anyone might be interest in seeing the "Heater Strip from Hell!" > > > >Jon Lechich > >X Marine Machinest > >Rebel Bird > >Bremerton Washington > > > > > > > >SPONSORED LINKS > ><http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w 3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recrea tional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_O bWmSYTw>Recreational > >vehicles > ><http://groups.yahoo.com/gads? t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=Z- 8HJdysB3QLPj9U0JvqYQ>Wanderlodge > ><http://groups.yahoo.com/gads? t=ms&k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge& w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34 cC1O9CxA>Automotive > >maintenance > ><http://groups.yahoo.com/gads? t=ms&k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderl odge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+ recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeY HfELr6o72IW1A>Recreational > >vehicle dealer > ><http://groups.yahoo.com/gads? t=ms&k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlo dge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+r ecreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L- kXbDI4ZSadEw>Used > >recreational vehicles > ><http://groups.yahoo.com/gads? t=ms&k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3 =Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreat ional+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq _4GlXA>Automotive > >radiators > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
