dash lights - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: dash lights (/showthread.php?tid=2028) |
dash lights - lafoyk@... - 02-20-2006 05:27 my dash lights went out on my 1968 wanderlodge. I check the fuses under the steering colume and there ok. please help. You can reach me at lafoyk@... thanks Kyle dash lights - birdshill123 - 06-08-2006 09:04 On my 88FC some of the lights work but some do not. How do you access the back of the guages to replace a bulb. Most of the sexy back lights for the dash panels are not lit. Are they bulb powered or? Bruce dash lights - g_man1146 - 06-08-2006 14:28 Hi Bruce, The dash panels are accessed by removing the screws around the outside edge of the panel and then tilting the panel toward the rear to access the underside. On my '90 and '99, I found that the easiest way is to tilt the steering wheel down toward the drivers seat and lift the top of the panel up toward the steering wheel. I use a wire tie through one of the screw holes near the center to hold the panel up against the wheel so I have two hands to work on the back of the individual gages/instruments etc. You will see easily accessible bulbs. As for the illuminated lines; these are electroluminescent panels powered by several small inverters that produce he higher voltage from 12VDC that is needed to light the panels. If the panels are damaged, or drilled in the wrong place, they will no longer light up. Usually, however, you will just need a replacement inverter. I don't know which panels you have problems with but if you post that info, someone will steer you to the location of the defective part. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > On my 88FC some of the lights work but some do not. How do you access > the back of the guages to replace a bulb. Most of the sexy back lights > for the dash panels are not lit. Are they bulb powered or? > > Bruce > dash lights - Curt Sprenger - 06-08-2006 15:11 Contact Stephen Birtles for the upgraded inverters for your dash panels. Worked for me. Stephen also sells the inverters for the florescent lighting. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. g_man1146 wrote: > Hi Bruce, > > The dash panels are accessed by removing the screws around the outside > edge of the panel and then tilting the panel toward the rear to access > the underside. On my '90 and '99, I found that the easiest way is to > tilt the steering wheel down toward the drivers seat and lift the top > of the panel up toward the steering wheel. I use a wire tie through one > of the screw holes near the center to hold the panel up against the > wheel so I have two hands to work on the back of the individual > gages/instruments etc. You will see easily accessible bulbs. > > As for the illuminated lines; these are electroluminescent panels > powered by several small inverters that produce he higher voltage from > 12VDC that is needed to light the panels. If the panels are damaged, or > drilled in the wrong place, they will no longer light up. Usually, > however, you will just need a replacement inverter. I don't know which > panels you have problems with but if you post that info, someone will > steer you to the location of the defective part. > > Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com > > > > > > On my 88FC some of the lights work but some do not. How do you access > > the back of the guages to replace a bulb. Most of the sexy back > lights > > for the dash panels are not lit. Are they bulb powered or? > > > > Bruce > > > > |
