Measuring converter output? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Measuring converter output? (/showthread.php?tid=2031) |
Measuring converter output? - Scott Forman - 02-20-2006 09:32 After doing some reading and some wire chasing, I have determined that my bus has a dual-output converter (Power Source 9180) with high or low voltage set via a toggle switch. Unfortunately, though, I do not know which setting is which on the switch. How do I determine what charge is being delivered at the batteries at a given time? Thanks Scott Forman 82 FC35RB Memphis Measuring converter output? - Jeff Miller - 02-20-2006 14:06 No idea where that converter came from but, ... With the batteries fully charged, you should be able to put a voltmeter across the output of the converter and see which switch position yields a higher voltage. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > After doing some reading and some wire chasing, I have determined that > my bus has a dual-output converter (Power Source 9180) with high or low > voltage set via a toggle switch. Unfortunately, though, I do not know > which setting is which on the switch. How do I determine what charge > is being delivered at the batteries at a given time? > > Thanks > Scott Forman > 82 FC35RB > Memphis > |
