Verizon air card continued - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Verizon air card continued (/showthread.php?tid=2109) |
Verizon air card continued - enow626@... - 03-04-2006 22:01 Joe, All ya gotta do is plug the card in the card slot and go - after installing the card software. In our case I bought an extended antenna which I've had to use maybe twice. One I remember is at Tony's RV service in Lexington, SC in his concrete block building in the boondocks. I plugged in the antenna extension and placed the antenna head outside the door and VOILA!!! Reception was fine!! Other time is in my computer room of my house again in a brick building. In this case I just stuck the exetension on the window pane and again VOILA!! The extended antenna costs I believe under $20. I often check transmission speed at _http://www.info-techs.com/speedtest500.html_ (http://www.info-techs.com/speedtest500.html) or I forgot the other site I use. Ed Nowokunski 95BMC37 [Non-text portions of this message have been removed] Verizon air card continued - Byrne Lobdell - 03-07-2006 01:15 Hi. my name is Byrne Lobdell in Louisiana and I have Verizon Broadband and a PC5740 air card from Verizon and there is no place to plug a antenna into. What card are you using and did it come from Verizon. Thanks, Byrne enow626@... wrote: Joe, All ya gotta do is plug the card in the card slot and go - after installing the card software. In our case I bought an extended antenna which I've had to use maybe twice. One I remember is at Tony's RV service in Lexington, SC in his concrete block building in the boondocks. I plugged in the antenna extension and placed the antenna head outside the door and VOILA!!! Reception was fine!! Other time is in my computer room of my house again in a brick building. In this case I just stuck the exetension on the window pane and again VOILA!! The extended antenna costs I believe under $20. I often check transmission speed at _http://www.info-techs.com/speedtest500.html_ (http://www.info-techs.com/speedtest500.html) or I forgot the other site I use. Ed Nowokunski 95BMC37 [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Mail Bring photos to life! New PhotoMail makes sharing a breeze. [Non-text portions of this message have been removed] Verizon air card continued - erniecarpet@... - 03-07-2006 03:21 Michael- what are you driving that is a non wanderlodge that has an 8v92? ernie-83pt40 in louisiana--just curious [Non-text portions of this message have been removed] Verizon air card continued - Michael Day - 03-07-2006 06:04 I have the Kyocera KPC650 card which I purchased from Verizon which does have an antenna port. I choose the Kyocera over a less expensive card specifically for that reason. Michael Day 8V92 non Wanderlodge --- In WanderlodgeForum@yahoogroups.com, Byrne Lobdell > > Hi. my name is Byrne Lobdell in Louisiana and I have Verizon Broadband and a PC5740 air card from Verizon and there is no place to plug a antenna into. What card are you using and did it come from Verizon. Thanks, Byrne > Verizon air card continued - enow626@... - 03-07-2006 07:23 I have the V620 air card which DOES have the external antenna connect. Ed Nowokunski 95BMC37 [Non-text portions of this message have been removed] Verizon air card continued - Tom McCarthy - 03-07-2006 13:24 Depending on manufacturer, ther should be a small hole in the end or at the hinge of the extending antenna. It is small and can be overlooked. The adaptor on mine has a tiny connector. Tom McCarthy --- In WanderlodgeForum@yahoogroups.com, Byrne Lobdell > > Hi. my name is Byrne Lobdell in Louisiana and I have Verizon Broadband and a PC5740 air card from Verizon and there is no place to plug a antenna into. What card are you using and did it come from Verizon. Thanks, Byrne > > enow626@... wrote: Joe, > > All ya gotta do is plug the card in the card slot and go - after installing > the card software. In our case I bought an extended antenna which I've had to > use maybe twice. One I remember is at Tony's RV service in Lexington, SC in > his concrete block building in the boondocks. I plugged in the antenna > extension and placed the antenna head outside the door and VOILA!!! Reception was > fine!! > > Other time is in my computer room of my house again in a brick building. In > this case I just stuck the exetension on the window pane and again VOILA!! > The extended antenna costs I believe under $20. > > I often check transmission speed at > _http://www.info-techs.com/speedtest500.html_ (http://www.info- techs.com/speedtest500.html) or I forgot the other > site I use. > > Ed Nowokunski > 95BMC37 > > > > > [Non-text portions of this message have been removed] > > > > SPONSORED LINKS > Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators > > --------------------------------- > YAHOO! GROUPS LINKS > > > Visit your group "WanderlodgeForum" on the web. > > To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > --------------------------------- > > > > > > --------------------------------- > Yahoo! Mail > Bring photos to life! New PhotoMail makes sharing a breeze. > > [Non-text portions of this message have been removed] > Verizon air card continued - Michael Day - 03-08-2006 06:15 I looked at Prevost's, Wanderlodges and finally found a 1992 Newell that already had a desk with a file drawer in it that we needed so I took the plunge. I love the Wanderlodges and would have jumped on one of them but with all the ones I found I would have had to remove a couch and have a desk custom built to fit in. I love this forum and learn an enormous amount from the comments. Michael Day 1992 Newell --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Michael- what are you driving that is a non wanderlodge that has an 8v92? > ernie-83pt40 in louisiana--just curious |
